Door Check straps and heater pipes
Griff55
Post by Griff55 »
Hi all, today I stripped out our '65 walkthrough but found that someone has just ground off the check strap points on the A pillars. Are these available anywhere or does anybody have any ideas where to get a pair please?
Secondly, I have cut the old cab floor out ready for the new one but am unsure on how to take out heater pipes behind front panel. Do I have to cut through welds to loosen them ir is there a magical way of removing them?
Many thanks in advance.
I'll get a thread started when I can get some pics.
BlastingDiePast
Re: Door Check straps and heater pipes
Post by BlastingDiePast »
Hello
To remove your heater pipe you do indeed have to cut the welds of then wiggle it like crazy, start with the most damaged or rotten bit normally the centre tube, cut out around the floor tube!
The rear Y section and through the floor bit are very hard to get hold of as is most of the front bits so be very gentle with them
Griff55
Post by Griff55 »
Thanks mate
