Engine Rebuild Time ???
matt d
Re: Engine Rebuild Time ???
Post by matt d »
BJ1 wrote: Then you will be able to cruise at 70+ in a 1960's tin box with no crumple zones or side protection :wink:
And have no legs worth using ever again. 8O :wink:
cyclosport
Post by cyclosport »
Finally got round to pulling the engine out and stripping it down.
Had to put heads back on, as I forgot to break the flywheel gland nut.
Took off heads, barrels and pistons.
Oil scraper ring on number 3 was broken - hence the smoke on start up.
Piston 3 and 4 looked a bit burnt.
Split case.
One of the Camshaft bearings had started to dis-integrate. Wear on the camshaft not that bad.
Middle bearing on crankshaft was really worn, looked like brass!
Crankshaft scored so will need grinding.
Case needs re-bore.
Stripped case down to shell removing fuel pump body, dizzy drive, pressed out oil pickup. Removed head studs.
Removed dizzy drive from case.
Need a puller to get off timing gear from crank and then it's off to an engine shop.
Anyone recommend any good engine shops that can re-bore the case, grind the crank and supply over sided bearings all round?
Marvelwear
Post by Marvelwear »
Jim grey at TES or get a short engine for about 450?or Turbo Thomas, paul? forgot his last name sorry, all near to you ish.
[img]http://i383.photobucket.com/albums/oo27 ... 902021.jpg[/img] 63 CKD Australian type2t1b School clothing bus from Melbourne called"Marvin"
cyclosport
Seriously not happy with one of the "companies" I spoke to about line boring the case.
You wouldn't believe this bloke - so called engine building "expert" who basically tried to con me into saying my crank "was bent" before he had even seen it and said it would cost over £300 to straighten it. I pointed out a new crank is less than that ...
Then he went on to say if the case was beyond it, the he could supply new engine case for around £800 !?£~@!!!
Again I pointed out a new case is in the region of £550 ....
And this guy is supposed to be an expert.
Was nice doing business with him. NOT!
You gotta laugh!
