Won't start
BusBug&KG
Won't start
Post by BusBug&KG »
Ok
Bus been standing for nearly two years,in barn,turns over,won't fire,tried fuel in carb,fresh battery,fired up moved out of barn.
Won't start turns but won't fire.
Must be old fuel.
Gonna drain tank in morning,remove and clean plugs,fit new battery & give her a fresh drink of fuel.
MUST WORK EH!!
Or am I missing something??
Tony C
andydlc
Re: Won't start
Post by andydlc »
Old fuel, crap battery or points closed up.. It will run, it's a vw! :wink:
Re: Won't start
Post by BJ1 »
andydlc wrote:Old fuel, crap battery or points closed up.. It will run, it's a vw! :wink:
At least clean the points - they will be pretty corroded on the surface.
Before you get it running - change the oil! Old oil can have loads of sludgy bacteria in it that play havoc with bearings.
cyclosport
Re: Won't start
Post by cyclosport »
I would flush the system of the old fuel as you say.
I had a generator that stood for 12 months and had to do exactly that.
Modern unleaded doesn't seem to last that long.
Re: Won't start
Post by maddison »
BusBug&KG wrote:Ok
....its not that one made of wood is it ??
Menace
Moderator
Re: Won't start
Post by Menace »
BusBug&KG wrote:Ok
Tony C
Yep you've not tried.........................
Thank me later :D :wink:
_______________________________________
N.Y.E. HARDCORE CAMPING POSSE 2005-2011
1957 Kombi
maddison wrote:SSVC should be how it is, real club for real enthusiasts, with a real forum of usable , storable data...to keep for all time
ratty mullet
Re: Won't start
Post by ratty mullet »
Have you tried changing the oil?
:blackeye:
Its the letters on the badge that count, not how shiney they are or how far off the ground !!!!!!
Neil :D
one of the 3 founding members of 'the curtain dodgers vw club'.
spike the paint wrote:ratty mullet is correct... :D
BusBug&KG
Re: Won't start
Post by BusBug&KG »
Got it going,it was the auto choke was sticking!
Took it for MOT today Failed,one front wheel bearing noisey & the usual head lights not to right pattern.
Not bad i suppose as been tucked up in my barn for over two years,say goodby to the velvet green for a while (needs some work) out comes the shiney wedding bus 1600 on reduction boxes,standard height,bog standard bus,except the colour.
YAWN,YAWN,YAWN.
How long will it be before it gets hit with the lowering stick??
Tony C
