red9 design front set up and irs can u use standard wheels
splitty61
Post by splitty61 »
hi guys,
with the red9 design front beam etc set up with thier 4 pot disc brakes and the red9 rear irs set up can you run standard 15 inch wide 5 wheels..
thank you
R32tom
Re: red9 design front set up and irs can u use standard whee
Post by R32tom »
You can run stock 15's with the hi-spec calipers, but 14's won't fit. You can run 14's on CSP calipers though. :wink:
SBS #34 UK
bex88
Post by bex88 »
Now that is interesting. It says no to 15's but someone else today was saying you can run 15's with the big brakes. R32 Tom you had the CSP's on 14's what's best. I had ruled out red 9 because I wanted to run the crows feet
nige1171
Post by nige1171 »
Markp is running 15" stock steels on Red9 discs. Not sure how but he'll tell you if you PM him.
Nige
My build thread...
viewtopic.php?f=8&t=69457
bex88
Post by bex88 »
A 4mm spacer. Don't think I would want to space the wheels out further when CSP is a option. Should find out next week if these 15s do fit or not. I know someone who is trying it
splitty61
Post by splitty61 »
hi nige,
just sent markp a pm mate thanks
nige1171 wrote:Markp is running 15" stock steels on Red9 discs. Not sure how but he'll tell you if you PM him.
Nige
R32tom
Post by R32tom »
bex88 wrote:Now that is interesting. It says no to 15's but someone else today was saying you can run 15's with the big brakes. R32 Tom you had the CSP's on 14's what's best. I had ruled out red 9 because I wanted to run the crows feet
I'd go for the hi-specs if I was running 15's. not a big fan of single pot calipers. But can't fit anything else on with 14's!!! :roll:
SBS #34 UK
Gaz2110
Post by Gaz2110 »
Hi there,
I have the Red9 with 4 pot cali's and 15 inch wheels!! No probs!
Gaz
Any pics to show clearance etc Gaz ?
DoubleD
Post by DoubleD »
The Red9 front end setup narrows the track by 40mm (ie. 20mm per side) so it should be feasible to use spacers for getting extra wheel-to-caliper clearance.
62ragtop
Re: red9 design front set up and irs can u use standard wheels
Post by 62ragtop »
sorry to dust off this topic, but my question is identical to the TS. Can anyone add some interesting new insights on this, after a few years?
Pics for reference would be great.
I called Red9 with the remark that some people are running 4 pot calipers with 15" crows. They state that it is not possible, unless spaced by at least 10mm.
Very interested in Gaz2110 solution as well
vwmorten
Post by vwmorten »
Where is the problem with clearance for 15" original splitwindow wheels?
I had som issues when i put them on my normal baywindow with discs and adapters, i found that the ATE calibers that i had was clearenced to fit, but the Girling calibers was a no go.
Is the problem the ball joints on the red9 setup?
rusty1962
Post by rusty1962 »
I run steel fifteens all round. The problem is the handbrake levers on the rear Hispec calipers....they foul on the webbing where the rim is welded to the centre.
Simon made me some spacers but they need to be 30mm to clear the levers. Hispec supply a slightly shorter lever too.......
visit my webshop
Halso Aircooled VW Oil
