Eberspacher fitting advice
ally5443
Post by ally5443 » Thu Jun 14, 2012 8:22 pm
I'm going to fit my d2 eberspacher tomorrow and got the base plate for it. This means cutting out a 5" hole in the floor :( under r and roll bed, bit tight with cross members etc but should fit. What do most people do with these,fit with base plate or drill 2 smaller holes for exhaust and inlet?
Ally
mclarni
Re: Eberspacher fitting advice
Post by mclarni » Thu Jun 14, 2012 9:19 pm
I drilled 2 smaller holes for inlet and exhaust plus a couple of other holes for fuel pipes and cables etc. Used the rubber gasket and some sealant between the unit and cargo floor. Also fitted under the r&r bed.
Nick
VOTM August 2012 :)
THE MARMITE BUS
viewtopic.php?t=47958
Ollie
Post by Ollie » Fri Jun 15, 2012 7:57 am
Make sure it works before you fit it!!
'it just bolts right up...'
ally5443
Post by ally5443 » Fri Jun 15, 2012 10:41 am
thanks good advice,got it all working on bench first
thinking of doing smaller holes and cutting lip off plate, just can't face cutting one big hole :(
the bus driver
Post by the bus driver » Fri Jun 15, 2012 2:10 pm
I've drilled several smaller holes, works fine!
Mine sits under the drivers seat tho!
Scott
Post by Scott » Fri Jun 15, 2012 2:15 pm
Stephan - where/how are you running the fuel hose to get to the front? Assuming you are coming off the tank?
the bus driver
Post by the bus driver » Fri Jun 15, 2012 6:23 pm
I have a splitter above the torsion housing, it runs through one the corners of the center chassis section into the left chassis leg together with the brake line.. simples :D
ally5443
Post by ally5443 » Fri Jun 15, 2012 9:11 pm
I was brave :wink: and cut out the 5" hole to use the plate, not much room so checked about 10 times and sh#t myself the whole time, bolted the ebber onto plate silicon and 4 self tappers, made a new loom as mine had been butchered. So just the exhaust and fuel pump and lines to do. Will get some photos up.
ally5443
Post by ally5443 » Fri Jun 15, 2012 9:20 pm
Stephan,
Great place for the ebber, wish I'd thought of that before I drilled a big hole in the back lol :lol:
the bus driver
Post by the bus driver » Fri Jun 15, 2012 10:02 pm
ally5443 wrote:Stephan,
You would never get it in like mine, as I have custom walk through :D
8)
richierich37
Post by richierich37 » Sat Jun 16, 2012 9:41 am
:lol: dangerman strikes again!!!! c'mon son, lets see these photos?!?!?! :cheers:
RICHIE C
SBS UK #37
P.B. 16.88 @ 77.1MPH
http://www.steeringboxscrapers.net/
ally5443
Post by ally5443 » Sat Jun 16, 2012 1:51 pm
Richie, you know you want a ebber!! it'll save you money on hats and gloves :lol:
Just for you bro i'll put some photos on the rides and projects.
richierich37
Post by richierich37 » Sat Jun 16, 2012 2:50 pm
ally5443 wrote:Richie, you know you want a ebber!! it'll save you money on hats and gloves :lol:
:lol: cheers dude! :wink:
RICHIE C
SBS UK #37
