L82 silver white
kev mc
L82 silver white
Post by kev mc »
getting my wheels powder coated and can someone confirm that L82 silver white is the correct colour for them, the bus is a 62 deluxe.
also as a back up does anyone know what the ral # would be incase they dont have the L# codes.
cheers
kev
visit us on facebook southcoast wagenwerks
vwsplitbus
Re: L82 silver white
Post by vwsplitbus »
Yes Kev that is the correct colour, not sure what Ral code is. Have you had a look on thesamba.com?
1953 21A Barndoor DK
1962 RHD Ragtop
1962 Lambretta ser3 LI125
I'm Down! R U? SBS #20
kev mc
Post by kev mc »
cheers.
done a search for the ral code and there seems to not be one, the ral code is a code they use in the uk mainly for powder coating, the guy asked me what colour they should be and mentioned ral code. i guess he will have to wet paint them and clear powder coat after. oh well at least they will be getting a coat of zink first.
vwsplitbus
When I had some powder coated they used RAL 9010 and they looked ok, thats as close as u can get I think with powder coat. (I may be wrong :wink: ) and the wheels were on a show winning bus.
Using the L82 paint is another option, but the finish is no where near as tough and long lasting as powdercoat.
1962 RHD Ragtop
Choc
Post by Choc »
I too have had the same issue Kev with L82.
I may just go for a slightly off white & get the bumpers done to match.
Sweet Rides
Post by Sweet Rides »
L82 Silver White is correct for the wheels and the bumpers of your bus Kev.
I have always painted mine but a mate had his powdercoated and we took in one of my wheels to the powdercoaters so we could get a half decent colour match off the charts for him.
I can`t remember what the RAL code chosen was in the end but I have to say that the match was pretty good, not perfect but acceptable for a driver IMO and I would be happy using it myself if I was going down the powdercoating route.
NOTE - IF POWDERCOATING THE WHEELS BE SURE TO REMOVE EVERY LAST TRACE OF THE POWDERCOAT FROM THE WHEEL NUT SEATS BEFORE FITTING THE WHEELS TO THE BUS - OTHERWISE THEY WILL COME OFF 8O This Job is best done with a fresh stanley blade or similar :wink:
BusBug&KG
Post by BusBug&KG »
Sweet Rides wrote:NOTE - IF POWDERCOATING THE WHEELS BE SURE TO REMOVE EVERY LAST TRACE OF THE POWDERCOAT FROM THE WHEEL NUT SEATS BEFORE FITTING THE WHEELS TO THE BUS - OTHERWISE THEY WILL COME OFF 8O This Job is best done with a fresh stanley blade or similar :wink:
GOOD CALL :!: :!: :!: :!: Also if painting
Tony C
An accident waiting to happen!!
rust is a must
kev mc
Post by kev mc »
cheers guys, gone for the 9010. they are getting blasted today, and then zink coated then i have to get four clips and fit them before they powder coat em....., now where to get the clips from.....
Choc
Post by Choc »
kev mc wrote:cheers guys, gone for the 9010. they are getting blasted today, and then zink coated then i have to get four clips and fit them before they powder coat em....., now where to get the clips from.....
If you find any clips can you let me know where from please?
kev mc
Post by kev mc »
decided as i cant wait i am going to rob them of some 14" wheels that i have :roll:
vwsplitbus
I have a pack of quality clips and pins. Think I bought them from Schofields vw a couple of years back but never used them.
pm me if you are unable to get any, I can post them tomorrow.
1962 RHD Ragtop
dave409787
Post by dave409787 »
A real dredge from the past, but was looking to paint my wheels, bumpers and front badge. Have already blasted them and etch coated them, was going to do a little filler work and then paint, but no space and weather is getting cold, so thinking about just powder coating the lot for speed, as need to get some tyres on them the next day ideally depending if they are hard enough :? ? . Did you go RAL 9010 in the end... how did they look colourwise?
Also, do they powder coat straight over the etch primer or strip it back again, and can they powder over light filler work? Did you need to prepare the clips for paint too? As i have brand new clips and bumper brackets to go on my already primed wheels. SOrry for all the questions on such an old thread, but it seemed the best place to put it. :D
WANTED
Number Plate light housing
Propex thermostat
Early church Key cover for engine lid
[img]http://img3.imageshack.us/img3/1854/1210237.jpg[/img]
Now called Trisha... found out she's a lady!
vwgillybilly
Post by vwgillybilly »
dave409787 wrote:A real dredge from the past, but was looking to paint my wheels, bumpers and front badge. Have already blasted them and etch coated them, was going to do a little filler work and then paint, but no space and weather is getting cold, so thinking about just powder coating the lot for speed, as need to get some tyres on them the next day ideally depending if they are hard enough :? ? . Did you go RAL 9010 in the end... how did they look colourwise?
My mate has just spent over a week straightening my o.g bumpers, prepping my wheels and sorting the front badge. My local sand blasters / powder coater said the match, quality of finish & durability of powder coating isn't as good as 2k paint. So I ordered 2 litres of Spies Hecker L82 Silver White - I'm more than happy so far, he's done a right job!
Gill.
1994 993 911
1967 SO42 tintop
dave409787
I have heard that 2k is more hard wearing, although i'd think powder would be enough. The main reason is i want to get them painted, tyres on and on the bus within 2 days, as that is all the time i have with the bus. Powder is fully hard once it cools, also the weather and my facilities aren't ideal for 2k at the moment.
I have since read that i'd need to use a chemical metal to fill that can withstand 400degrees.
However, was there any other code for the L82 that was provided with your paint as so far every code i've found and used, my local paint shop can't identify.
WANTED
Propex thermostat
Choc
Post by Choc »
Just spent two months (on & off) straightening my o.g bumpers, prepping my wheels and sorting the front badge. My local sand blasters / powder coater said the match, quality of finish & durability of powder coating isn't as good as 2k paint. So I ordered 2 litres of Spies Hecker L82 Silver White - I'm more than happy so far...
Gill.
Would be interested seeing the results as my wheels and bumpers need to go the same way. :D
