will a 6v fuel gauge work in 12v system ?
Will a 6v fuel gauge work in a 12v system ? or will i need a voltage dropper ? cheers guys paul
yip you need one of them, cheap enough though
http://www.bigboystoys-uk.com/
Voltage reducers 12v - 6v
For use with low current devices such as chokes, semaphores etc. 12v - 6v. Solid state
Price - 9.95 GBP
Price - 9.95 GBP
SSVC MODERATOR
http://www.buseswithattitude.co.uk
I tried to make my own before I bought one from Peter, the Maplin one is the same as he uses. The only trouble I had was that you've almost got to keep it/solder it in sterile conditions! or any static in the slightest will render it usless, I made 3 or 4 and when I ran a test meter through them it kept showing 12v. Got one from Peter, it showed 6v and worked!!
RHD '63 13 window deluxe
1989 BMW E30 M3
1989 BMW E30 M3
http://www.type2.com/library/electris/wire6v12.htmsplitscreencharlie
My bus runs on 6v at the min. what would be the pro's/con's of converting it to 12v??????
SSVC MODERATOR
Sorry VW Buzzers; that link is not really the most helpfull or technically accurate I regret to say - in my opinion of course.
I have a range of technical guide on converting from 6 to 12 volt systems giving far more practical options, including changing generators. Please email me if antone wants a copy. peter@volksgoods.fsnet.co.uk Peter Good
sorry about that peter your dead right i was on my way out and did a quick post. I have done a couple of conversions but defo put my hands up to the king of electrics. Don't suppose you have a decent size diagram of how to wire in my footswitch i only have a wire running to each headlight/ no main or side lights and my eyesight doesn't seem to work on the small pics. (1962 lhd us import)Sorry VW Buzzers; that link is not really the most helpfull or technically accurate I regret to say - in my opinion of course.
vwbuzzers@hotmail.com
SSVC MODERATOR
- bigbulli
Me too! Works vry well!shawn wrote:Got mine from Peter Good on here, £6 inc postage, works well,
Barndoor Mirror Arm Screws - http://www.thesamba.com/vw/classifieds/ ... id=1620078
Thanks for all the good comments guys - much appreciated.
It is quite true to say there is a lot of really useful stuff for VW owners on the web and through the forums like this one.
Unfortunately, and with no doubt the best of intentions, some technical write-ups do fall a little short, and I think it right to point this out on the fairly rare occassions when it happens.
Enough of my rambling! Haven't got a diagram, but will knock one up and email it to you... Peter G
thanks peterHaven't got a diagram, but will knock one up and email it to you... Peter G
SSVC MODERATOR
