Cab door hinge pins removal - I made a tool !!!
Campo
Post by Campo »
Forgot about this, still sitting in the garage, anybody want to borrow it PM me, just cost you the postage.
Tony
Vorsprung Durch Technik (Progress through technology)
Vorsprung Durch Patina Split (Progress with style)
Haycoxs
Post by Haycoxs »
Hi Campo
PM'd ya
I've always been in the sh*t, it's just the level that changes!
robs_uk
Post by robs_uk »
Hi Tony,
i would like to borrow it obviously i would reimburse you the post. CHeers Rob
vwsplitbus
front cab door hinge pin puller
Post by vwsplitbus »
vwbuzzers wrote:great idea got the same tool just need a reason to remove my doors
Hi having trouble with one of my door pins :oops:
and was reading a thread above, you mentioned you had the tool, any chance I could borrow it?
thanks Mike
vwbuzzers
Re: front cab door hinge pin puller
Post by vwbuzzers »
thanks Mike
Yes you can pm me just before the weekend meet to remind me. Failing all that I'm not a million miles away
bu54ter
Re: Cab door hinge pins removal - I made a tool !!!
Post by bu54ter »
Hey guys,
Just a quickie!
When you replace the door pins do you run a reamer through the holes first, is so does anyone have one which can be "hired".
I got some pins from wolfsburg west, so i need imperial reamers, either 0.317" or 0.321. Or will i just have to buy the 8.5mm and a metric reamer?
cheers guys?
Plums
Post by Plums »
bu54ter wrote:Hey guys,
Just a quickie!
cheers guys?
I am in the same position with regards to the 8.5mm arms & it will be best to get yourself an 8.5mm hand reamer. Failing that get an adjustable one and us a micrometer, if you have one, to get the size spot on with your arms, as these will more than likely be slightly different in size.
Make sure you use some sort of cutting compound for a spot on size. If you dont it could cut the hole oversize and you will be in the same situation as before. :wink:
1966 Black 11 window
1954 Kombi
1968 Lambretta SX200 (TS230)
massivesplitproject
Post by massivesplitproject »
just reading this thread and can i say what a good idea and what a truly nice guy
nick
Post by nick »
joey in the states makes these,,, perhaps the club could buy one and charge a £1 everytime someone needs it... im sure it would pay for itself eventually...
http://www.thesamba.com/vw/classifieds/ ... ?id=522550
http://www.thesamba.com/vw/classifieds/ ... ?id=478847
raiz
Post by raiz »
[quote="Campo"]I am as smug as a smug person who has just won first prize in a smugness contest :D :D :D
OMG i know you, you live in smuggsville near smugchester dont you! LMAO :bounce:
SBS UK#25 Image
SPLIT 1
Post by SPLIT 1 »
I think its a bit far to post for me, so I am about to have a go at making one, any hints,
I dont want to buy one as I will only use it twice, just got one door to do.
Dave
64 RHD 13 window deluxe
Waiting??????
Scousey12
Post by Scousey12 »
Hi.
Just seein the best way to remove pins to change a door and came across this !! Is it still available to borrow plus postage of course. ?
Regards
Daz
