Cab door hinge pins removal - I made a tool !!!
Campo
Post by Campo »
I am as smug as a smug person who has just won first prize in a smugness contest :D :D :D
I tried all the usual ways to remove the cab door hinges so I could fit my 'proper' side mirrors (except heat as I did not want to damage paint work any more) with no success.
Finally came up with this :
Its a modified ball joint splitter tool (had to hide it from the missus as she threatened to use it on me if I spent anymore time in the garage 8O )
The 'forked' end has been ground flat and the 'bolt' end has also been ground out to get the tool to fit over the hinge.
I also had to grind the diameter of the pin to fit in the hinge pin hole.
Basically works like splitting ball joints, the 'fork' end fits around the top of the hinge pin and the threaded pin pushes hinge pin from underneath.
Mirrors are now fitted complete with authentic vibration, even with 'harp' arms. 8) 8)
Anyone want to borrow it let me know
Vorsprung Durch Technik (Progress through technology)
Vorsprung Durch Patina Split (Progress with style)
thebouncingbunny
Post by thebouncingbunny »
good call and if the ball joint splitter was anything like the one ive got -it seems the same-its probably the best use for it as its rubbish at splitting ball joints!!!!
bunny
filby
Post by filby »
thebouncingbunny wrote:good call and if the ball joint splitter was anything like the one ive got -it seems the same-its probably the best use for it as its rubbish at splitting ball joints!!!!
bunny
ditto know what ill be doin with mine to now then
busjunkie
Post by busjunkie »
Whoa!
I was just about to start a thread on 'any other methods of removing stuck pins (other than Mike1973's suggestion of 'plenty o' WD40 and a lump hammer') and came across this one!
I tried a similar approach with a small clamp but the thread part started to bend!
how do you get the device to sit under the pin if its all the way home and you can't budge it?
paulbugman
Post by paulbugman »
can you do it without taking door off
Campo
Post by Campo »
Took a picture to show how I used the tool (on the bottom hinge cause I've already removed the top hinge pins):
Did it without taking the door off
The hinge pin did not sit fully through the hole so it was straight forward to locate the bolt/pin of the tool in the hinge against the bottom of the pin.
Mart
Post by Mart »
Looks like a great idea
i also am suffering with not being able to see behind on the near side.
how much would you want to hire it out?
thanks Mart
Spares assistant. SSVC Committee member
If life gets too much
Drive a BUS
Voltworks Electrical Services
Tel:07946534096
Campo
Post by Campo »
Mart No problem
Just PM your address and I'll send it to you, just send it back when you've finished with it with a couple of quid to cover postage.
Not looking to make any money out of this just glad to help out.
Tony C
Byron Bamboo
Post by Byron Bamboo »
I'd love to borrow this as I have a hinge pin on the nearside and no mirror..
It does look like it will damage the paint though without 'protection'
:D
The Gaffa Tape Tour 2007
'58 RHD PGSG Microbus
Campo
Post by Campo »
I did scuff the top of my hinge a little, first one was worse than the second as I got used to using it.
Mirror arm covers up the worst of it, however my bus has lots of 'character' in the bodywork so its not too noticeable, strategically placed piece of rubber under the forked end would probably do the trick.
althesparky
Post by althesparky »
thats neat, beats a chisel and lump hammer!
Mart
Post by Mart »
thanks tony
am going on holiday on sat so will get in touch when i get back as it looks like other people are intrested.
thanks Mart
Drive a BUS
Tel:07946534096
UZI
Post by UZI »
nice.
............ wrote: refreshingly swell comments.
Haycoxs
Post by Haycoxs »
Hi Campo
Need to get my old mirror arms out - will this work on mirror arms as well as just hinge pins?
If so matey can I borrow it sometime please?
Ta
I've always been in the sh*t, it's just the level that changes!
vwbuzzers
Post by vwbuzzers »
great idea got the same tool just need a reason to remove my doors
