splitty safety
mrga
Post by mrga »
ta very much for the info. i'll let you know re the bracket after i take a good look at what my bus has/hasn'tgot in the way of an upper mounting point..
cheers again
gareth
ratatatat57
Post by ratatatat57 »
paul_f wrote:
kempy wrote: CSP disc's can be used with standard wheels as long as 15".
It's a great piece f kit. Just a shame my sprints cover it up.
They definately don't. They only fit over the Chrome 356 wheels.
Paul
They deffo do fit over standard bus wheels,but you have to use the 14inch disc kit which is specific for busses running wide 5 crows foot rims,if you use the 15 inch kit then you have to use beetle rims.If you go on the CSP site it gives you the 2 options and what wheels you can fit
I have just seen a roll cage which is the dog on a split not a million miles from me and the guy has made templates so he can do more,you can just see it with the door open,shut and it is not there,goes all the way accross the front panel and is super strong :)
Hickory dickory dock, my rats gone round the clock!
paul_f
Post by paul_f »
Paul
That was quite an old post :wink:
ratatatat57
sorry didn't look at the date was just trying to be helpfull :(
bmac
Post by bmac »
hey all.
just thought i'd jump on the safety band wagen !!
do you like what I did there !!!!
I way on Youtube earlier and spotted this VW related safety video.
not a split but a later van, rather worrying as i've got a pickup myself, only a whole load older than this one. (with no seatbelts and oldskool brakes!!)
check it out here http://www.youtube.com/watch?v=TPpU5azjCB8
worth noting that it looks like they had it going faster than it's capable of going on it's own. So unless you drive it off a cliff you probably won't experience this.
bobley
Post by bobley »
IIRC thats done at ~ 70mph with a full load on the back. Not exactly representative.
jonnolly
Post by jonnolly »
Yeah thanks for that you tube bit..........really cheered me up!
Flat4onthefloor
Post by Flat4onthefloor »
If you drive sensibly, Keep your distance, and have dual circuit brakes, even if they are drum brakes and properly maintained, this will improve the safety of your van.
I will be putting a full cab cage and 4 Point Harness's into my panel as i want to be able to drive it reasonably quickly every now and again, They aren't built to withstand a big impact, metal is only 5mm thick!
Dual Circuit Brakes (discs for more reliability and less fade when over worked)
Cage
Seat Belts 3 Point Minimum,
Strengthening bars welded inside the doors? Protect on a side impact?!
I cant think of anything else that could help us survive better if the worst happened.
And as prepared as you can be you have to remember it will never be as strong as a modern car.
My 2 pence worth!
Fast and Low! Thats the way to go!
Soundcatcher
Post by Soundcatcher »
You can buy seatbelts direct from http://www.quickfitsbs.com/ who supply VW Heritage. So the guys can make them to order in the colour you want and the length you need. They also have all sorts of additional fixing stuff that you can't buy from the standard retailers.
Such as if you have children and you want to have aircraft style belts they can also supply standard clips (like you have in your regular water drinking car!) that can be detached as apparently they are tested on child seats and are safer. So you can have the best of both worlds. I haven't explained it very well but if you give them a call they explain it much better!
Oh and yes I've got 3 point inertia for driver and passenger and a lapbelt for the dwarf in the middle and in the rear 3, 3 point inertia belts for the rear seat and I'm still trying to figure out how and what to fit for my forward facing 2/3 seat in the middle of my '65 Ambulance............Fixing points are an issue at the mo!
T2
Re: splitty safety
Post by T2 »
I'm looking for these mobile "neck-protective head-stoppers" (hehe dont know the correct english-word). Looks like this ...-->
http://www.vwnorge.no/index.php?action= ... 2272;image
Any web-shop tip ? :)
Soundcatcher
Re: splitty safety
T2 wrote:I'm looking for these mobile "neck-protective head-stoppers" (hehe dont know the correct english-word). Looks like this ...-->
http://www.vwnorge.no/index.php?action= ... 2272;image:)
Luv it....clip on headrest anyone??? :lol:
Soundcatcher
Re: splitty safety
Just had a quick look around. I remember looking for these years ago only to find that hens teeth are easier to get hold of! :wink: In fact high back Vw seats are easier to get your hands on than these little gems! :? Might try a VW breaker such as http://www.volksheaven.co.uk. You could also keep you eyes open on http://www.thesamba.com, in fact it might be worth placing a wanted ad?! Other than that I don't think they are being reproduced?! Unless someone else knows better??? :?:
T2
Re: splitty safety
Post by T2 »
High back seat's are really not an option for me - it ruins the look of the car. BUT - again - I like my neck too - so I think a mobile unit would be great. Hide it - when PRIDE is parked 8)
T2
Re: splitty safety
Post by T2 »
Bump 'n up to the top
Soundcatcher
Re: splitty safety
I just found this http://www.thesamba.com/vw/classifieds/ ... ?id=760330 and I thought of you!!!
Image ImageImage
He who learns but does not think, is lost! He who thinks but does not learn is in great danger.
