Front Beam Options Technical Topic
Re: Front Beam Options Technical Topic
64 split rat wrote:
Is it just me, or do those wheels look really forward in the arches?
SPLIT 1
Post by SPLIT 1 »
Same here, I thought that???
Dave
64 RHD 13 window deluxe
Waiting??????
Dipsy
Post by Dipsy »
SPLIT 1 wrote:Same here, I thought that???
Dave
I thought it was just me! has it got some weird shorter trailing arms on?
Nige
'El <ex> Presidente'
paul_f
Post by paul_f »
They only normally look that far forward if you have just lowered it on adjusters, no dropped spindles.
The arms are so far around the arc that they are nearly pointing vertical
Dipsy
Post by Dipsy »
paul_f wrote:They only normally look that far forward if you have just lowered it on adjusters, no dropped spindles.
Smartarse :lol: :wink:
Nige
64 split rat
Post by 64 split rat »
the wheels are turned slightly!!!
are you down? uk#11
flojo
Post by flojo »
Sorry I am trying to get my head around this so I can decide what to do on my bus am I right in thinking if you do an sa conversion it will lower the rear more so you have to fit adjusters and dropped spindles but if you are just doing an irs as its not as low you can get away with just dropped spindles?? :D
Project 1966: https://www.ssvc.org.uk/phpbb/viewtopic ... 8&t=121834
VW Splitscreen, 1966 RHD, Devon Roof, Dormobile Interior
Creative Engineering IRS Kit
bobley
Post by bobley »
Doing an "IRS" conversion or swing axle will lower the rear of the bus by as much as you like. Normally just swapping in an SA conversion drops the rear about 2.5" but you can change the level of drop by fitting the springs and springplates in different places to give further adjustment (adjustable spring plates makes the process much easier). Fitting drop spindles drops the front by 2.5" but the drop is fixed, if you want to go a bit higher or lower then you need to fit adjusters to fine tune it. If you plan to go lower at the front you may need to look at tyre options. If you use alloys (which often stick out more than stock wheels) then you may need a narrowed beam. If you keep stock wheels then you may get away with no change or you could get a lower profile tyre.
I always think I know whats going to happen when I lift / drop / narrow etc but something always catches me out - so its best to just fit everything and get all the opportunities for adjustment!
flojo
Post by flojo »
Thanks Bobley am a little clearer! so much for thinking I was getting the hang of this its sooo blooming complicated :D
bobley
Post by bobley »
I fitted a narrowed beam and dropped spindles earlier in the summer and although the bus looked a lot better the handling went out of the window and the front tyres started rubbing even more than they used to even though the clearance was much greater. The only major difference was that because the beam was narrowed I couldn't refit the anti roll bar.
I chopped 75mm out of the middle of the ARB, then welded it, sleeved it and welded the sleeve. I've just been for a spin - its a different bus!!! Its really planted to the road and doesn't roll at all. There's no rubbing or wallowing and it drives much better (I would say its like a kart but I think that would be pushing it). The only problem is that the welded bar is an MOT fail so I'm going to take it to a blacksmiths and and get a copy made out of one piece of steel.
If you haven't got an anti roll bar and you'd like to improve the handling of your bus I can thoroughly recommend it.
Overdubbed
Post by Overdubbed »
I'm just about to buy a split that has been irs'd and has a bay front beam. The tyres are 185/55.15 The front suspension seems realy soft and the tyres rub really badly. The shox are new, but don't look special. Also the bus tracks all over the place - feels like bump steer. The steering box looks about 4" off the ground. There are no signs of any adjusters on the beam - I wonder if someone has "left out" a leaf or 2 from the beam to soften/lower it? Ideas please!! I have to make a buying decision a bit quick on this!!!
Bergy
Post by Bergy »
can't you just take it off when you have an MOT?
If you are going to all that trouble, it might be worth having a couple of 2" and 4" ones done to sell no?
bobley
Post by bobley »
I hate MOTs as it is. I just want it right with no mucking about. I'm still enjoying the welded bar for now. My CE beam is 75mm narrowed. I doubt other beams are exactly 2 or 4" either so I'd rather measure up first.
Bergy
Post by Bergy »
if you go ahead and have one made, any chance you could do the same for me once I know the length needed?? Won't be for a long time mind you :wink:
bobley
Post by bobley »
Okay, I'll let you know nearer the time.
