Engine cuts out
chrystal
Engine cuts out
Post by chrystal »
Twin carb, electric fuel pump on a 2110. Engine runs fine etc until......
Going down a very steep hill and braking at the bottom, the revs die off and the engine stalls. Starts first time. Happens regardless of the amount of fuel in the tank.
Any ideas? Cheers
There's a lady who's sure all that glitters is gold
and she's buying a stairway to Heaven
When she gets there, she knows if the stores are all closed
with a word she can get what she came for
Re: Engine cuts out
That's a new one on me...
chrystal
Re: Engine cuts out
Post by chrystal »
Ha ha, that wasn't what I was hoping for when I saw that you had replied😀
richandsue
Re: Engine cuts out
Post by richandsue »
all i can think of is that when the van is pushing the engine down hill it is still taking in fuel and not burning it all off, and sort of flooding. but then technically it would not start straight away. Bit of a puzzler. is it a steep hill , maybe the van does not like the hill. :cheers:
chrystal
Re: Engine cuts out
Post by chrystal »
Ok, cheers. I do get a bit of popping now and again when I come off the accelerator, the plugs are sooty. It currently idles 1100. Maybe I need to get the carb settings checked?
The engine was done on a tooling road when built by John Mahar in 2018, but due to a serious oil problem has been rebuilt, would that mean the carbs need 're balancing etc?
Re: Engine cuts out
Post by ted698 »
Has it got a Servo? Sudden vac leak on the servo pipe? Relatively common on Bays. Cuts out when braking.
Re: Engine cuts out
ted698 wrote: Thu Aug 27, 2020 8:44 pm Has it got a Servo? Sudden vac leak on the servo pipe? Relatively common on Bays. Cuts out when braking.
I would of expected that to happen all the time, rather than just on steep hills / poor starting etc too
Re: Engine cuts out
chrystal wrote: Thu Aug 27, 2020 10:52 am Ok, cheers. I do get a bit of popping now and again when I come off the accelerator, the plugs are sooty. It currently idles 1100. Maybe I need to get the carb settings checked?
Sounds like you have several things going on. The 1100 idle could be masking various things. Set the tappets. Get the carb linkage balanced and screws adjusted evenly if its twin carbs. Set idle down to 900'ish and the timing. Then go from there. Might have a gasket sucked in on the inlet which is causing the idle issue if its not simply poor adjustments.
chrystal
Re: Engine cuts out
Post by chrystal »
Thanks For that. No servo, yes twin carbs. Timing and tappets just done. If i leave it, will damage be done to anything? We are in Greece and rolling roads/ experts arnt that plentiful😀 There was a rolling road 3 miles away from me in Essex!
philsparks
Re: Engine cuts out
Post by philsparks »
What carbs do you have?
What pressure is the fuel pump set at?
Are you running a 009?
Sent from my HRY-LX1 using Tapatalk
chrystal
Re: Engine cuts out
Post by chrystal »
Twin Webber 40s, yes 009. Fuel pressure, don't know
philsparks
Re: Engine cuts out
When you go down hill are you using engine braking?
Does it do it if not in gear?
chrystal
Re: Engine cuts out
Post by chrystal »
Engine breaking is fine, cuts out if not in gear or clutch depressed
philsparks
Re: Engine cuts out
What happens if you leave it idling sat still on a steep hill for a few minutes?
How long is the steep hill.?
If you coast down out of gear does it still do it?
chrystal
Re: Engine cuts out
Post by chrystal »
Update...
Taken to a a rolling road in Theassaloniki. Re jetted and adjustments made. Wow....what a difference! thanks all.
