Wiring issues
chrystal
Wiring issues
Post by chrystal »
Rhd 65. Having issues with lights. Both headlights work on full and dipped. Neither sidelights work. Rear drivers side tail light doesn't work, passenger does. Both brake lights work. Number plate light doesn't work, I know it gets it power from drivers tail light though.. lastly rear indicator, drivers side, doesn't work, front and passengers do.
I have checked the tail light bulbs, all ok. Not checked the indicator bulb yet. I have temporarily run a wire from passenger side to drivers side tail light, which then works, so guessing the earth is ok?
I'm thinking light switch? Not checked yet a we need the van for next 2 days and have looked at the switch before which took a while 😁
Any help appreciated!
There's a lady who's sure all that glitters is gold
and she's buying a stairway to Heaven
When she gets there, she knows if the stores are all closed
with a word she can get what she came for
Dougie
Re: Wiring issues
Post by Dougie »
I can't do anything electrical without a multimeter. They only cost about £20 but make sure it measures continuity. With a tester wire long enough to easily reach the back of the van and a crocodile clip at each end you can easily check all your wires and switches are good, connected properly and getting power. It's just a question of being methodical taking each light in turn.
SSVC Club President
chrystal
Re: Wiring issues
Post by chrystal »
Hi, thanks. Yes I have one and know there is no power to the rear trail light, I know I will have to look at the switch, but it is spaghetti behind the Speedo and not a quick job, I normally cause more problems than I solve initially😁 just hoping that it would be something easy that I have missed. Normally I would have days to spend on this, typical.
chrystal
Re: Wiring issues
Post by chrystal »
chrystal
Re: Wiring issues
Post by chrystal »
All sorted, my fault, put in new headlights and not put the screw holder thing on properly, so the sidelights contact was shorting on the headlight housing!
chrystal
Re: Wiring issues
Post by chrystal »
