Fuel pump pushrod
El torro
Fuel pump pushrod
Post by El torro »
Is this operated by cam on crankshaft or camshaft,on my rebuilt engine it does not seem to move,very strange,going to fit electric pump anyway but just curious
Dougie
Re: Fuel pump pushrod
Post by Dougie »
Drive comes from the distributor drive shaft. Very odd that it doesn't move as the engine turns over
SSVC Club President
El torro
Post by El torro »
Yup engine runs,I know the dizzy drive is not in proper location but solved by moving spark plug leads,will try and do pressure test as I have put another fuel pump on
El torro
Post by El torro »
Other fuel pump worked ok, did not realise spinning engine over on starter got push rod going up and down thanks to previous reply about 2 revs of engine equal one pump
Post by 8 8US »
El torro wrote: Tue Aug 18, 2020 6:53 pm Other fuel pump worked ok, did not realise spinning engine over on starter got push rod going up and down thanks to previous reply about 2 revs of engine equal one pump
There are two different push rod lengths, 100mm and 108mm, for two different pumps. Do you have the correct one?
https://www.heritagepartscentre.com/uk/ ... -type.html
El torro
Post by El torro »
Yes correct length for Dynamo ,I had two spare fuel pumps the Brazil one was knackered but VW one with inspection plate worked fine
