Oil Pressure Light and Switch
Dot
Post by Dot »
Morning All,
I’m still going through the Bus I’ve bought and I’ve one problem that I’m about to embark on, the lack of green light on the dash. Bulb checked and is ok. Engine appears fine but won’t be happy until this issue is sorted and I’m not driving it on the road atm.
Looking in the engine compartment it’s got an extension to the oil pressure switch which I’ve not seen before. Anyone guide me as to what it is please, and can I or do I remove it?
I’m planning on installing a gauge in the cab, any advice appreciated. I’m wondering if I’ve got a wire continuity issue...
Pic attached as is...
Thanks all
Dot
'59 import Mango... plus a liberal sprinkling of rust....
Re: Oil Pressure Light and Switch
Post by 8 8US »
Dot
That extension is to allow an additional sender (pressure or temp) to be fitted, looks like it is blanked off.
Have you grounded the wire in the engine bay? The bulb should light, if not it is a wiring issue which you can test by running a temporary wire outside the bus between the sender and the bulb. If it does light it'll be the sender is duff.
As Richard said, except its not backed off, its got an oil temp sender fitted but not wired up.
As the bus is new to you, don't assume the idiot lights are wired up the correct way. Put the ignition on, see which lights are working. Remove the cable to the charging warning light (either off the alternator or off the dynamo regulator). Does the charging light go out?
And with the help of an assistant, as Richard said, touch the oil pressure cable to earth, does the light come on?
Dot
Post by Dot »
All sorted, thanks Jim and 8Bus. Green light working A1. Although the additional part in there appears to have a larger thread so i've had to retain it for now.
Dot wrote:
Sun Oct 20, 2019 3:42 pm
Cool.
What was the reason for it not working before?
