Engine fails to start after it's been running
frilly
Post by frilly »
Hi all , been out for my first run in my 56 single cab, engine seamed fine untill I tried to start it straight after I stopped it! Any ideas as to why this may be? Did start again after a period of time. Kind regards neil
Re: Engine fails to start after it's been running
Post by 8 8US »
Neil
Could be a number of things, is it a new loom or the original? If original the solution can be a hot start relay to take the load off the wiring, could simply be a dodgy solenoid, or a connection issue somewhere in the switch or the cabling.
Take a look here:-
https://www.ssvc.org.uk/phpbb/viewtopic ... 0&p=910923
frilly
Post by frilly »
Hi , it's the og loom ( now running 12v) also I'm using an og switch and key . It cranks over but fails to start! Fuel pump maybe? Kind regards neil
Post by 8 8US »
Oh sorry, thought it wouldn't turn over.
All you can do is go back to basics, fuel & spark, are they there?
frilly
Post by frilly »
I'm going to need another pair of eyes to check for spark! The inline fuel filter was empty if I remember after it stopped (yes half a tank of fuel) I'm wondering dodgy fuel pump
frilly wrote:
Sun Sep 15, 2019 9:54 pm
What is your starting procedure when cold and hot?
frilly
Post by frilly »
Quick tap on throttle to engage choke when cold , just turn key when hot! Is that normal?
richandsue
Post by richandsue »
try bump starting it . if it starts ok then it is a wiring problem to the starter motor. may need another pair of hands though. unless you stop on a hill. :cheers:
frilly
Post by frilly »
Fair point, it doesn't seam to turn over fast enough (battery charged and reading full) so you may be onto something with the starter!
james309
Post by james309 »
frilly wrote:I'm going to need another pair of eyes to check for spark! The inline fuel filter was empty if I remember after it stopped (yes half a tank of fuel) I'm wondering dodgy fuel pump
Debris in tank restricting / blocking fuel supply ?
Sent from my SM-G960F using Tapatalk
jayvanman
Post by jayvanman »
In my limited experience I'm inclined to say starter or battery. Even if battery is charged and reading 12v that doesn't necessarily mean the amps are there to turn the starter with enough grunt.
If you can get your hands on a battery that you know is in tip top condition I would try that 1st. Maybe another splitty owner in the neighbourhood could help out. At least then you know that will be one potential cause off your list.
If you've not changed the starter to a 12v starter and it's not turning fast enough that sounds wrong to me.
6v starter on a 12v system should be turning twice as quick so I'm inclined to think starter.
To try another battery won't cost anything so I'd start there.
Fuel.
Take the filter off and stick your finger down the choke and pull the throttle lever. If your finger gets wet and smells of fuel, then you've got fuel.
The nice thing about these engines is that they are mechanical.
You can work it out , think where the problem might be and work through a process of elimination.
Good luck.
Jason
he who sins grins
frilly
Post by frilly »
Hi Jason , I'm running a 12 v starter, starts fine from cold , run the truck for a couple of miles say then turned off . Won't start again straight after , does seem a little slow at turning over so may try your battery suggestion . Thanks for your help
DaveyMoon
Post by DaveyMoon »
If its slow to crank when hot then your starter may be suffering from heat soak. I had this problem and a new starter fixed it.
The optimism of the action is better than the pessimism of the thought
73 Devon Holdsworth
61 Kombi
tman
Post by tman »
We had this problem with our 6v Oval Beetle. It was caused by the starter motor bush in the bellhousing expanding/binding and slowing the starter when warm. A new bush fixed it, it's supposedly a common problem.
Andrew
tman
Post by tman »
DaveyMoon wrote:
Wed Sep 18, 2019 8:18 am
Coincidentally, just seen this on thesamba.com: https://www.thesamba.com/vw/forum/viewt ... p?t=725848
Andrew
