Remote servo
splitintwo
Remote servo
Post by splitintwo » Thu Aug 08, 2019 6:52 pm
Fitted VWjims servo kit and finally getting around to the brake pipe work.
Is there an inlet and outlet on the servo?
I plan on using the tee on the two front pipes from the m/c and take a line from the tee all the way to the remote servo on the end, and use the top outlet and return another line to the m/c with one blanked.
Does that sound ok?
Decided to install here. This is the progress.
Pic taken from the front.
https://flic.kr/p/2gSQKH7
Pic taken from the cargo door area
https://flic.kr/p/2gSRBFV
Bolted along walkthrough
https://flic.kr/p/2gSQKGf
Not sure why there is a tiny access hole but used it today 👍🏼https://flic.kr/p/2gSShrp
Re: Remote servo
Post by vwJim » Thu Aug 08, 2019 7:09 pm
Take one pipe from the mc to the servo for the front circuit.
Take another pipe from the mc to the servo for the rear circuit.
Blank all the other mc outlets.
From the servo to a T to the front brake.
From the servo to the rear T for the rear brakes
splitintwo
Re: Remote servo
Post by splitintwo » Fri Aug 09, 2019 6:34 am
Thanks Jim👍🏼
