Negative camber irs
chrystal
Negative camber irs
Post by chrystal »
I have negative camber on an irs bus. The clamps are Harry Harpic bolt ons. I Have read that the clamps can be undone and moved to rectify this.
Firstly, does the wheel and hub need to come off to be able to move the clamps?
Secondly, how much do imove them and in which direction?
Any hints welcome!
There's a lady who's sure all that glitters is gold
and she's buying a stairway to Heaven
When she gets there, she knows if the stores are all closed
with a word she can get what she came for
Splitzter
Re: Negative camber irs
Post by Splitzter »
You'll need to loosen the bolts & rotate the clamps so that the arm moves upwards. You can tap them round with a decent copper mallet or use a jack/lump of metal under the arm where it's bolted into the clamp. How much is hard to say, how much camber have you got?!
Some drink from the fountain of knowledge, others just gargle...
chrystal
Post by chrystal »
Iwill post a pic hopefully,. If I move them up wont it lower the rear a bit more?
chrystal wrote: Mon Jul 01, 2019 2:51 pm Iwill post a pic hopefully,. If I move them up wont it lower the rear a bit more?
Minimal effect on ride height. You'll been to redo the tracking though during the process.
henk
Post by henk »
I also have bolt on clamps,from another brand.
I had to turn them up quite a bid to get rid of the negative camber.
I even had to cut down my Y-heater pipes.
Wich was no probleme for me.
Henk!!!
chrystal
Post by chrystal »
Did you take the wheels and hubs etc off? Or just have a trolley jack on the arm, loosen the bolts and raise it slightly?
chrystal
Post by chrystal »
Did this today, didn't move them enough! Another go tomorrow. Thanks for your help
It often takes a few tweaks to get it level / correct camber as the springs settle after being adjusted, especially if they've been out of spec for a while
