Bus judders when pulling away
Starsky2727
Post by Starsky2727 »
Hi like most I recently pulled my van out for the summer. last month when I went to Ninove I noticed when driving along the motorway about half throttle the bus would occasional judder only very briefly.
it progressively has got worst pulling away under load I now start kangarooing down the road in 2,3 or 4th. would this be a clutch issue or something else ?
the gearbox/clutch ir only a couple of years old with 2k miles done.
any advice appreciated
thanks
Aaron
Re: Bus judders when pulling away
Check the clutch cable adjustment / bowden tube is correctly installed / main clutch cable conduit hasn't broken free. Other than that I'd suspect oil contamination of the friction plate.
Starsky2727
Thanks Jim I’ll take a look. If it’s oil contamination I’m guessing the engine needs to come out then
Yes, if oil or the conduit broken free, then it's an engine out job.
New seal(s) + new friction plate if oil.
Weld the conduit in position if broken free.
Starsky2727
Thanks Jim
Bowden tune looks ok and has the right amount of bend
Conduct if this the tube the Bowden connects to which then runs under the belly pans then that looks ok 2
Clutch looking the likely culprit
Is the engine wet where it joins the gearbox?
Starsky2727
vwJim wrote:Is the engine wet where it joins the gearbox?
There is a wet patch at the bottom of the box
That's often where the flywheel or gearbox seal leaks collect
Starsky2727
Clutch is out. Didn’t see any oil contamination on the friction plate. Looks a cheap clutch and pretty rough looking seeing it was only put in before I bought the bus 3 years ago. I bought a new kit from Machine7. ImageImageImageImageImageImage
Still not 100% think this solve the issue and it might be electrical. Fingers cross
Old clutch
BJ1
Post by BJ1 »
Electrical? How so? that old clutch plate look oil soaked to me. Have you found the leak? No point putting in a new clutch if the crank oil seal is leaking.
1966 SO42 Westy in Velvet Green - on the road at last!
1967 Sundial from Idaho
1971 Westfalia from LA
DOUGAL
Post by DOUGAL »
Hi Aaron,
Did you get it fixed?
Also check gearbox mounts.
Link to forum post
Starsky2727
Just back from the Garage
Turned out the vacuum distributor was faulty... At least the bus got a good service
Valve tapper check
Weber ICT 34 rejected and cleaned
New ignition leads
Looking forward to getting to the AGM now !!
DOUGAL
Post by DOUGAL »
See you there!
Link to forum post
See you there.!
Starsky2727
type21f wrote:See you there.!
Be nice to meet you Mr G and see your Devon
