Fire Extinguisher Systems and fuel cut off valve
russvw66
Post by russvw66 »
HI Where can I buy afire extinguisher system and a fuel cut off valve. what is best FOAM, POWDER.
How much will this cost
Re: Fire Extinguisher Systems and fuel cut off valve
Fuel cut off after tank
Look at Durite valve..
I have fitted with key switch in cab.
You can tailor the input and out out to change size. I fitted large tank outlet to alloy ceramic filter and then to durite fuel valve and then through tin ware to mechanical pump.
So fuel cut off and filter are under the bus not in engine bay.
Sjtw
Post by Sjtw »
As above, for buying, try VWJim and vwaircooledworks for the two most popular types of extinguisher
I believe vwjim may no longer be supplying the Firetec system.
I have two of this system. they are/ were ...when available excellent!
Vwjim is now supplying an alternative. Ignis system
type21f wrote:
Fri Apr 19, 2019 10:22 pm
I believe vwjim may no longer be supplying.
I have two of his systems.. there are/ were ...when available excellent!
Vwjim?
I've restarted doing them, as an ex-employee of the company that I used to buy them from has started his own company. Same specifications as before. Foam filed, chafeguard etc.
Jim
