Dropped spindles back to standard?
63CorvairSplit
Location: Weymouth, Dorset, Fitting a smaller engine in the van!
Post by 63CorvairSplit »
Hi - I have dropped spindles on my van (it’s actually a 68 bay with a king link pin front end)
I’m considering putting it to stock height- I don’t think it is, but it’s worth me asking - is there anyway I can convert my dropped spindles back to standard height ones?
Would it be a case of rearranging them? I have feeling the track rod end bits were machined so maybe I can’t do this?
Cheers, mike
Build thread here :)
viewtopic.php?f=8&t=92787
ernie
Re: Dropped spindles back to standard?
Post by ernie »
Probs plenty of people willing to do a swap with some cash your way...easier for you and a few quid in your pocket too...I would go that route!
63CorvairSplit
Hmm - never thought of that - not a bad idea . I kind of liked the idea of being able to swap it back if I liked that’s all!
No, you shouldn't revert them back, as they have been machined which could weaken them.
63CorvairSplit
Thanks. - the machining you refer to - how come that doesn’t affect them when they are ‘dropped’ currently?
If there are any safety issues, there is no way I would consider this - just purely for my interest, trying to understand what process they go through when they are changed to be dropped.
In loose terms.....
In stock format, the weight is split between the upper and lower bushes / LP / trailing arm etc.
In dropped spindles format, all the weight is on the lower bush / LP / trailing arm etc with the upper bush mount now only really acting as a guide. The upper spindle area is clearanced to allow the LP to be flipped 180 degrees. So if you use them in stock format that original weight is acting on a reduced spindle body thickness.
Hard to explain.
63CorvairSplit
No - thats a great explanation and makes perfect sense. I imagine that dropped spindles would receive more wear in that lower bushing and linkpin then.
Looks like if i want to do this, i'd be looking for a swap deal or to buy some recon stock spindles outright then :-)
THanks, Mike
63CorvairSplit
Or actually the best option for me will probably to buy a whole 2nd hand front beam, trailing arms and ball joint spindles which i can fit to my 68 bay :-)
63CorvairSplit wrote:
Mon Apr 15, 2019 12:47 pm
THanks, Mike
:cheers:
