1500 Bus Engine Oil Cooler Seals
81dubber
Post by 81dubber »
Hi all
Currently replacing Oil Cooler Seals on a Standard Non Dog House Oil Cooler.Engine is a 1500 Bus Engine,Engine No H 5135045.Some Confusion over type of Seal to fit.Do I need the Tubular Rubber Seals or the Stepped Type?.The ones that came off the Engine are the Stepped type.The Ones in the Gasket Kit I ordered are the Tubular Rubber Ones.Could anyone tell why they are different, as I only want to do this job once!.
Thanks in advance
Tomas
Re: 1500 Bus Engine Oil Cooler Seals
Post by Who.Me? »
81dubber wrote:
Sat Jan 12, 2019 4:39 pm
Hi all
Thanks in advance
Tomas
I found this helpful. Skip to 1:27...
https://youtu.be/Bs9GFxayyUA?t=86
81dubber
Post by 81dubber »
The video has cleared things up.I’ve got the Original Style Cooler,so the Tubular Rubber Seals should be fine.
Tomas
amd
Post by amd »
Hope this is of some use, last year my bus had a large leak ( the oil cooler seals had been siliconed !! ) Garage replaced and all ok for a week then it started again, took it back and turns out my cooler and engine block are different , one early the other later so needed the stepped ones. The difference is small and was overlooked the first time round, all ok now.
