Rear arch clearance
PIPKIN
Rear arch clearance
Post by PIPKIN » Sun Aug 05, 2018 11:28 am
Hi all,
I'm mid restoration and have a niggling concern about the clearance between my rear arches and wheels.
I've fitted new long and short side panels that have a different profile on the arch. Additionally, the bus has irs suspension, CSP rear disks and BRM alloys.
Photos of new side panels.
Has anyone else fitted this combination without clearance issues?
Restoring a splittie is like have the worlds biggest meccano kit but someone has thrown away the instructions.
vwbuzzers
Re: Rear arch clearance
Post by vwbuzzers » Sun Aug 05, 2018 10:12 pm
For sale section ?.
Buzzers
PIPKIN
Post by PIPKIN » Mon Aug 13, 2018 1:06 pm
For sale section ?.
Buzzers
Hi, I did try to delete it but was unable to?
Paul
mjknight71
Post by mjknight71 » Mon Aug 13, 2018 7:15 pm
I'm not 100% sure what you mean the sides are different to each other or to what you took off?
They look flat early arches....did you have late flaired/lipped arches.
I don't have your exact rear set up but I do have flat arches and getting the wheel off requires the damper disconnecting to allow the suspension to drop enough to squeeze the wheel through.....don't think late arches are so much of a problem. Only running 175 width tyres.
No issues when driving....cannot remember the et of my wheels
PIPKIN
Post by PIPKIN » Tue Aug 14, 2018 6:06 pm
Cheers for the information.
Yes took of late arches, repair panel from a previous ownership, and now have the early flat arches.
Sounds like a bit of juggling is needed to get the wheels on and off. But looks like I don't have an issue.
Appreciated.
