Toe in
philsparks
Toe in
Post by philsparks » Wed Jun 13, 2018 4:41 pm
Hi does anyone know what the correct toe in setting for the front wheels is for a 64 on dropped k&lp?
Thanks phil
Sent from my SM-J320FN using Tapatalk
philsparks
Re: Toe in
Post by philsparks » Thu Jun 14, 2018 2:00 pm
Any idea where to find the spec for this?
Re: Toe in
Post by BJ1 » Thu Jun 14, 2018 4:49 pm
Do you mean dropped spindles Phil? If so then toe in is the same as normal - 0 to 2mm. I just set mine at 1mm.
philsparks
Re: Toe in
Post by philsparks » Thu Jun 14, 2018 5:21 pm
I have done the camber angle on the shims. I need to adjust the tie rods for the toe in angle.
philsparks
Re: Toe in
Post by philsparks » Thu Jun 14, 2018 5:22 pm
Sorry yep dropped spindles but I don't think that affects the toe in?
Re: Toe in
Post by BJ1 » Fri Jun 15, 2018 7:30 am
That's right - so set them as specified in the factory. 0.04" or 1mm toed in.
philsparks
Re: Toe in
Post by philsparks » Fri Jun 15, 2018 7:55 pm
Thanks I will try that tomorrow
