Non starter
Robbievanguy
Re: Non starter
Post by Robbievanguy » Sun Jun 17, 2018 5:53 pm
Was thinking that as well maybe an option kadrons are gettin a bad rap,thanks for all the help cheers rob.
Re: Non starter
Post by ted698 » Mon Jun 18, 2018 3:53 pm
I have Kadrons on mine - and I love them - I think they a great simple carbs and they transformed my bus.
Check you don't have fuel dripping out of the brass pipe (accel pump) that goes into the throat of the carb, if this is dripping the accel pump is still
over adjusted too far - common!
Have you read the tuning notes from KaddieShack (the Kadron guru) if you follow these you can't go wrong - unless there is something physically wrong with your carbs - links to the Tuning & Tech guides below.
http://www.kaddieshack.com/tech-articles.html
http://www.kaddieshack.com/tuning-instructions.html
Robbievanguy
Re: Non starter
Post by Robbievanguy » Mon Jun 18, 2018 5:22 pm
Hi thanx for the help ,adjusted the accelerator to 4 or 5 MM they were away out at 20mm so to much fuel think the mixture is out that's next ,at least it's running ,have checked caddy shack vids really good have learned loads how did you adjust mixture how many turns etc .cheers rob.
