3 Point Seat Belt Moounting in a factory Microbus
63CorvairSplit
Location: Weymouth, Dorset, Fitting a smaller engine in the van!
Post by 63CorvairSplit »
Has anyone seen a microbus with a 3 point seat belt on the middle bench folding seat next to the doors?
This is actually for a 68 Swedish Bay, but I figured a late split shouldn’t be too different!
It has the factory seat belt mounts with white plastic plugs in them. I can see on the other side, I can fit the 3 point belt, but on the folding seat side next to the door, the mounts are there, but the belt would pull across the gap between the rear bench and the middle bench seat making it a pain to get in and out of the back.
The mounts are there, so I figure there must be a way of doing this!
Thanks, Mike
Build thread here :)
viewtopic.php?f=8&t=92787
