Headlight switch
wizard 1066
Headlight switch
Post by wizard 1066 » Wed Dec 13, 2017 10:16 pm
We have a dimming headlight switch, it dims the speedo and fuel guage when twisted, the problem is we think it might be faulty as the insrument lights always look dim.
Is there a way to check if its working as it should as its difficult to see the speedo in the dark.
Re: Headlight switch
Post by clymoj » Wed Dec 13, 2017 10:45 pm
One way to check it is to bypass the connections which relate to the speedo dimming. I can’t remember which they are but look at the wiring diagrams on thesamba and it’ll tell you which terminals on the back of the switch to bypass.
It is essentially a simple rheostat so adds variable resistance from max current downwards. I.e. it attenuates a max current downwards rather than turns up the brightness. When it’s turned to max it is effectively bypassing its own resistance circuit and just providing the current output at whatever it receives.
I have had two break and when they do you lose dimming below where the break in the coiled resistance wire is, ie it starts to dim and then suddenly goes to nothing. So it is unlikely it has broken in a way in which it permanently slightly dims the lights as you describe. However check as above because there may be corrosion or poor connections which are limiting throughput when it’s at max.
Hope that helps, I’m not an electrician so may have used the wrong terms, but I have taken a couple apart so I know roughly what they do.
Post by clymoj » Wed Dec 13, 2017 10:52 pm
30 Red cable + supply unfused from battery
56 White /black + supply to dip/main relay
58 Grey Side light supply to fuse box
58b Grey/ Orange Panel back light supply
So 58 is the unattenuated supply and 58b is the attenuated / variable / dimming one for the dash lights.
So from memory if you unplug your dash light wire from 58b and attach it to 58 you will see what full brightness looks like.
By the way for what it’s worth my full brightness is pitiful by modern standards, I have to hide my satnav because it is too bright by comparison. You get used to it though.
I’m sure someone does LEDs to replace dash bulbs these days too but don’t know whether they’d be dimmable.
Post by type21f » Thu Dec 14, 2017 6:31 am
I have all my 12v dash instruments and 4 gauges illuminated by LEDs on my 64.
I really like being able to see the gauges...lol
I bought them from USA from an advert on thesamba.com.
Sold by a hippy guy..
They are dimmable but remember if you have an alternator you must buy the gizmo so it does charge.
The seller could not remember if he had posted my order and sent me a second set.. which arrived first..
He apologised if the first lot arrived saying ENJOY..
If anything they are too bright on full!
I bought an NOS spare switch years ago...but have not had to use it yet..
I fitted new 6v bulbs to my Firetruck and they are bright enough.
wizard 1066
Post by wizard 1066 » Wed Dec 20, 2017 10:14 am
Thanks for all your help guys, going to try cleaning all the terminals first so see if it makes any difference first and then go through all the suggestions and see what happens, will post the results once its done, LED might be a route as we have gone LED with the interior lights.
jayvanman
Post by jayvanman » Wed Dec 20, 2017 3:17 pm
Wizard pls post up your outcome as I have the same problem.
Jason
he who sins grins
wizard 1066
Post by wizard 1066 » Sat Dec 23, 2017 8:50 pm
Well we cleaned up all the terminals and that did improve things a bit, we ran a live feed to a few of the connectors as clymo suggested and things brightened up, a change of the bulbs might help or led bulbs.
We have a new rev counter on the dash wired into the same system and thats working OK to a point, it dims the same as the others but is still brighter then the dash light, also the fuel guage needle keeps going across to full when we rev the engine, maybe another electrical fault to cure. Back to the drawing board.
Post by clymoj » Sun Dec 24, 2017 11:22 am
Fuel gauge should earth directly to the dash which if you’ve ever had a repaint or had the gauge out may not be making a proper connection.
You can run a separate earth from the back of the gauge case to somewhere you have a better earth which may improve things.
wizard 1066
Post by wizard 1066 » Sun Dec 24, 2017 6:32 pm
Thanks, found out it was just a bad earth, maybe through looking at the other wires we disturbed something.
