Is that two items or bought as one item?
I see the idea...
Remote oil cooler
Re: Remote oil cooler
- vwJim
I don't use that brand, but C / D is just the flow to / from the cooler, so doesn't matter.
It’s 2 items from the same seller on evil bay, they’re spec’d for an10 but they will swap out for the any an size of your choice.
Grant
Cheers Grant...
Thanks for replying..
The mist is clearing...
All new to me..
I have used Torques AN fittings with my remote but the incorporation of a cooler...Ahhh
All new to me..
I believe the concept racing cooler in an8, I called and they’re fitting an10 to mine. I’m thinking larger pipe ID = more oil.
Ah...gazpilot wrote:I believe the concept racing cooler in an8, I called and they’re fitting an10 to mine. I’m thinking larger pipe ID = more oil.
Knowledge is a powerfull thing!
I have a Concept racing cooler and will have the same diameters all the way through...
Changes in dims may not make any difference..
Back to my hydaulic swing crane fitting training in Sweden...
LOL
I think I would sleeve all those holes to stop the cross member filling up with crud.........but that's just my "belt and braces" mentalitytype21f wrote: ↑Fri Nov 10, 2017 6:13 pmOn that instal no Heat exchangers and no heater tube installed.. So a large single hole.vwJim wrote:Sandwich plates CLOSE when the oil gets to the set temperature, not open. Therefore force oil to go through the cooler.
Question on that belly pan. How does the air flow out? Scoop pulls it in, but no outlets?
On mine I have multiple holes all across the rear cross member.
Resto http://www.ssvc.org.uk/phpbb/viewtopic.php?f=8&t=97975
"J Rax" Handmade front & rear roof racks and clamps for Dormobile buses
visit my webshop
Halso Aircooled VW Oil
If you think you can, you can and if you think you can't, you're right
visit my webshop
