Engine running problems
Rich W
Post by Rich W »
Help needed
Have a new 1776 engine with twin Weber 34 ict carbs fitted, standard fuel pump and fuel regulator fitted.
Will fire up and run for a short time but not long enough to warm up and respond to accelerator, will then cut out sometimes re-starts but not for long or will backfire loudly, after that won't start at all until following day.
I've tried various ways to start but no difference, any advice would be appreciated.
lids_2001
Re: Engine running problems
Post by lids_2001 »
Get another body to help set the throttle linkage then just screw in the idle screws until it runs, even if slightly more than 900 rpm. If this doesn’t work then it will be a case of working through all the possible issues until they are all eliminated. Did the engine builder install thhe engine as well?
Tourist exchange with optional extra of a rubber mat!
Rich W
Post by Rich W »
Engine was supplied as turnkey and all set up, I installed it.
lids_2001
Post by lids_2001 »
You must have removed carbs etc to install, I reckon it’s out of sync
Rich W
Post by Rich W »
Didn't have to remove carbs as the icts are quite small, nothing altered from delivery of engine just connected fuel lines etc.
Robgrav
Post by Robgrav »
If all you’ve had to do is connect fuel lines then it’s a fuel issue. What regulator is on it.
Rich W
Post by Rich W »
Filter King regulator pre-set and supplied with engine, I feel that it is a fuel problem but can't find out what the problem is
lids_2001
Post by lids_2001 »
remove in line filter, remove fuel cap. See if it runs? is the backfire through the carbs? if it is then its lean
Check that you've got the fuel lines on the filter King the right way round because on the instructions that came in the box with mine they were shown the wrong way round. Ran like a bag of poo until I swapped them. The fitting that pokes out horizontally goes to the carbs (hope that makes sense) and the one that points downwards goes to the fuel pump.
Rich W
Post by Rich W »
Filter King was supplied fitted, also has an arrow on it for direction of flow, fittings are both horizontal. Backfire sounded as though from exhaust, will try removing filter and fuel cap. Thanks for input guys.
lids_2001
Post by lids_2001 »
check your timing, backfire through exhaust is normally ignition related, but not always.
Post by flatbeat »
Sounds like you're over feeling. Starts and runs when cold....being overly rich is like having a cold start choke....but once a little warm it'll stumble and stop? Backfire through the zorst also suggest over fuelling so try winding in the idle mixtures and leaning it off a bit.
Rich W
Post by Rich W »
After checking all possibilities of a fuel issue including float heights, adjusting mixture screws and checking fuel lines engine is now running perfectly, not sure what the actual cause was but it's running great now. Thanks again for the suggestions.
