6 volt or 12 volt
Slippers
6 volt or 12 volt
Post by Slippers »
I have a 66 registered bus which was manufactured in 65 would this have left the factory as a 6 or 12 volt? Reason for asking is that the wipers seem to run very fast and I was thinking that perhaps it has been converted to 12 from 6.
As always any advice would be greatly appreciated.
Re: 6 volt or 12 volt
There was an option to have 12v fitted from new complete with 12v battery cover. All the factory fitted items were 12v.
Check your m codes.
Does the bus have a 12v battery?
Around then VW fitted 2 speed 12v wipers!
Is yours 2 speed?
Are you selecting fast?
If the bus has been converted to 12v then the wiper motor may not have been converted to 12v.
Early breadlof motors easy to convert.
65 with frame much more difficult.
66 67 with cylinder body no idea
vwed is the wiper expert.
Wiper motors draw high current so people do not fit voltage droppers that often.
They get very hot!
vwed
Post by vwed »
As above, the M code for a 12 volt Bus is M620.
If your Bus is originally from the States it is likely to have this.
UK/European Buses remained 6 volt until the start of the '67 model year (August '66) when they too became 12 volt.
As above, I would have thought a quick look at your battery will give you the answer!
Slippers
Post by Slippers »
I understand what you are saying but why would a quick look at the battery tell me if the bus left the factory with a 12v battery or if someone changed it at a later date?
Slippers wrote:I understand what you are saying but why would a quick look at the battery tell me if the bus left the factory with a 12v battery or if someone changed it at a later date?
How is the battery strapped down?
It would have / should still have a 12v battery cover and longer battery strap.
The mcode plate should have the m code on it.. m620
The wiper motor part number would be for a 6v or 12v
The fuel gauge would be for a 6v or 12v..
Easy to see if it started as 12v..
Slippers
Post by Slippers »
Ah, I see what you mean now (not usually this stupid!!) the wipers are two speed and both seem to be pretty fast, perhaps that is how it is supposed to be. It has the cylinder type motor and I have been told that a Freelander one can be used to replace it with not to much modification so perhaps I will give this a try. Thanks for the info.
vwed
Post by vwed »
Bear in mind that both the 6 volt and 12 volt cylindrical wiper motor were 2 speed.
Best to look at the part number.
211 955 111 Q = 6 volt.
211 955 113 Q = 12 volt.
Slippers
Post by Slippers »
Brilliant, you certainly are a hive of information.
...told you..LOL.
