Flywheel nut removal issues
Biglozzer
Post by Biglozzer »
Ok so all day today I've been trying to remove the flywheel nut on my 2276cc engine. First easy issue was it isn't a standard 36mm nut. Mine is a 38mm which I've used a 1 1/2" socket that fits.
It's seized on there solid.
I've used a pry bar and a SNAP ON torque multiplier x 4 which would normally shift anything. No joy
I've tried a 6 foot scaffold pole over the pry bar and it's lifted the engine plus one adult off the floor. No joy.
I'm assuming the original engine builder used lock seal on the nut as some do and it's literally 13 years later glued it on.
I've got a worn leaking main seal behind it so need it off.
Any better ideas?
I'm thinking of heating it to burn off the lock tight. I don't possess a oxy set up though.
Next step is two more mates to hang off 6 foot pole and no doubt snap the pry bar!
Been a long wasted day. So any help appreciated
Thanks.
1959 OG paint Mango bus with curved Devon interior. http://m.youtube.com/watch?v=bEVPMkZUEes
1955 Dove Blue micro bus
1959 Canadian Mango micro bus
1970 Porsche 914
2004 Harley Davidson Road King
1959 MGA Roadster
richandsue
Re: Flywheel nut removal issues
Post by richandsue »
feel your pain. can only suggest heating as you mention. but when hot have the scaffold bar on it under tension with another person, and then hitting the bar with a sledge hammer to try and shock it off :(
Heat should soften the thread lock, if that's the cause.
Or take the engine and the socket to a tyre shop and ask them to put the air gun on it. Preferably a place that does truck tyres as they'll have monster guns.
Post by clymoj »
I chiselled my old one off in the end. Took about an hour and obviously totally screwed the nut but it worked
Biglozzer
Post by Biglozzer »
Thanks guys. I'll let you know the result as and when I get the dam thing off.
1970 Porsche 914
1959 MGA Roadster
Biglozzer
Post by Biglozzer »
We'll update for today. Brand new pry bar snapped. Heat made no difference. So arranging for a mobile plant machinery guy to come out in week to use heavy duty air tools and try that.
Never know one to be this bad must have been put on by a gorilla!
1970 Porsche 914
1959 MGA Roadster
lids_2001
Post by lids_2001 »
You need to borrow a torque meister.
Tourist exchange with optional extra of a rubber mat!
Biglozzer
Post by Biglozzer »
lids_2001 wrote:You need to borrow a torque meister.
I've already tried in original post! Didn't touch it.
1970 Porsche 914
1959 MGA Roadster
lids_2001
Post by lids_2001 »
When I had a crank and flywheel as a single assemblyI took the lot to a tyre shop as mentioned above and they took it off for a tenner. Used huge impact gun
malum
Post by malum »
I have one of these
http://www.ebay.co.uk/itm/3-4-Dr-Torque ... 2749.l2648
If there's something to lever against i.e. somewhere for the bit with the holes in to jam against (a nut or a socket on a nut) this should take it off. It's a 64x multiplier.
Made short work of my hub nut that bent a 40inch 3/4" breaker bar with me jumping up and down on the end.
Biglozzer
Post by Biglozzer »
Well it's off! My mate in the Royal Engineers let me borrow a 4 foot very heavy duty breaker bar used on tanks! It still needed the 6 foot scaffold pole over top but with two of us hanging off it it gave in with a loud snap. As suspected a liberal application of lock tight was dried solid and present. So happy days. thanks to those who gave advice.
1970 Porsche 914
1959 MGA Roadster
Post by clymoj »
Great news. Happy ending :)
How on earth did you hold the engine still?
Post by BJ1 »
vwJim wrote:How on earth did you hold the engine still?
Best way to do this is to bolt a long steel flat bar to the flywheel using the clutch bolts, resting it on the ground. I have a thick bar drilled for clutch bolts, wheel nuts etc. Makes the job much safer and easier. Does the rear hub nuts as well without any dramas.
Biglozzer
Post by Biglozzer »
Two big blokes holding it pinned to floor. Nightmare but glad sorted.
1970 Porsche 914
1959 MGA Roadster
