Wheels and spacers problems
tomvaughan
Post by tomvaughan »
I run stock wheels and have a straight axle conversion with spacers. Despite torquing them regularly it's impossible to get them really tight and they have a tendency to work themselves loose.
This has meant one of the wheels especially has some lateral movement and has worn grooves in the wheel bolts. Anyone got any thoughts on what I can do to improve the situation. New bolts and new spacers aside?
Aspro
Re: Wheels and spacers problems
Post by Aspro »
Pretty sure you're using the wrong bolts on those wheels mate. Shouldnt they be radius rather than cone.
Stevep
Post by Stevep »
Hi, original wheels need radius bolts you have taper bolts you can buy washers to convert them.
Aspro
Post by Aspro »
Thought so. Very dangerous as they sit. Explains why they're working their way loose
Stevep
Post by Stevep »
tomvaughan
Thanks all - I was coming to that conclusion myself after some thought. Will get them swapped straight away
Looking at the drums and wheels, you've done a fair amount of damage there too.... You may find the wheels are beyond use if the surface profile has been worm.
Those taper bolts have be around into the drum, damaging the initial part of the mount. Be very careful after you swap to new bolts that he problem doesn't continue. Oh, and definitely don't re-use those taper bolts with collars. Start with the correct bolts.
tomvaughan
New bolts ordered and on the way. Most of the damage seems to be to the spacers underneath rather than the wheel itself, so I may end up getting new spacers too but will obviously keep a close eye once they are swapped.
