1500 single port performance.
Jrnbru
Post by Jrnbru »
Evening.
Just a bit of information wanted really.
I've tried the search bar but nothings came up with the answers I wanted.
So I have the 1500 sp in my restoration project. I want to keep it. It's going to get a fill rebuild and hopefully a few trick bits to aid performance/cruising speeds. I know it's never going to be fast as such just a slight increase would be sweet.
Im coupling it up to an irs set up and as it'll be fully rebuilt will be running sweet. Anyone have any suggestions as to the best performance mods? Cams, rockers etc??
And what works well with eachother.
Thanks a lot
Joe
ducatis
Re: 1500 single port performance.
Post by ducatis »
Firstly these are generally considered great stock engines.
There in lies your dilemma. As I see they don't really lend themselves to performance upgrades
If you start increasing the heat levels the case lacks the oilways to keep it all as it should......
Personally id keep that motor as it was intended. If you need more get a 1600 dual relief case and build a bit on that...
Good luck on which way you go
Sent from my E5823 using Tapatalk
Remember to like
http://www.facebook.com/vwsambavan
Doing the samba.... (sometimes the panel)
Jrnbru
Post by Jrnbru »
ducatis wrote:Firstly these are generally considered great stock engines.
Thanks mate. I know there great little engines and supposedly the most reliable which is what I want. As long as it's capable of cruising at around 60/65 with the irs set up I'll just rebuild it standard as that's all I want to be fair.
Joe
Disco Stew
Post by Disco Stew »
How about a small twin carb kit like 34ICTs?
Jrnbru
Post by Jrnbru »
Disco Stew wrote:How about a small twin carb kit like 34ICTs?
It's an option mate. Just wanted a few ideas really, will these need any supporting mods as such?
Disco Stew
I think a freer flowing exhaust would also help. Not sure if you can keep the vacuum advance distributor or if you'll need to swap it to a 009 or similar.
ernie
Post by ernie »
To be totally honest mate, i think you are going to struggle with a 1500sp mated to irs.
Irs gearing saps a lit of oomph out of your engine & hills are going to be a struggle
ducatis
Post by ducatis »
I had same problem in my '66. In the end sold the engine which wasn't original anyway, and went 1776...
My only small regret was following my boy racer instinct and going for a noisy induction and exhaust.
As brilliant as Webbers and a Vintage speed exhaust are the system is too loud on a long haul....
I also have IRS, welded and higher 4th gear - which does help on the long runs....
I drive around around 65 - 70 on a long road
Remember to like
Jrnbru
Post by Jrnbru »
ernie wrote:To be totally honest mate, i think you are going to struggle with a 1500sp mated to irs.
Balls ha. What's the best option then straight axle? I'd love to keep the 1500 as it's the original engine and I like the idea of it being reliable lol.
george21
Post by george21 »
My view:
1679 thick wall slip in barrels&pistons
Light port, clean heads
Better flow exhaust
100 cam (optional)
Twin ict
=brilliant stockish reliable engine
readyboy61
Post by readyboy61 »
:lol: No striaght axle achieves the same problem as IRS its jsut a differnt way of connecting the wheels to the gear box. :lol:
Your right the 1500SP is a cracking engine and seen by many as the best type 1 engine VW built, however your mistake is getting rid of the reduction boxes and choosing to go with IRS or even straight axle (the outcome is the same as its the gearbox the counts) which realy need a 1600 or bigger in a bus to work.
The reduction boxes with a 1500cc engine are your friend for cruisng up hill and past others with irs/staright axle with a 1600 or 1641 in the back and probably a 1776.
I have a 1776 IRS and no way in hell would i go for anything smaller unless i had the reduction boxes.
Jrnbru
Post by Jrnbru »
Ahh OK mate. Thanks for the info. Maybe I'm gonna have to get a bigger engine as I wanna go low.
Thanks for the info mate
Post by clymoj »
I have a 1500sp with IRS on my very lowered bus and it's great
Full camping interior plus roof rack and gear with two of us is fine. I've had six people in with no luggage also fine
Yes you have to go slower up the long hills when you're loaded up but that's like 10-20 minutes of a four hour drive to Cornwall. And your cruising is probably going to be more like 60 than 65 - mine would happily do 70 but I think I coked up the cylinders a bit with my overexcitable right foot so I'll be sticking to 60 once I've rebuilt it
But it is fun to drive and mine was bombproof until I took the bus off the road for resto so depends what you want to achieve
kevsplitty
Post by kevsplitty »
I have a stock 1500sp with reduction boxes in my original single cab,to be honest it pulls really well up hills,quick getting away but is flat out at about 55/60. In my 15w i run a 1776 twin dells, a 6 rib bay 091 box & irs'd it flies along & will sit on 70 at 3500rpms no probs,just depends which way you want to go. I love them both equally,one makes me chill & happily plod along the other i wanna overtake everything :lol:
Dont walk take the bus!
Rutland Hardcore Posse 07/08/09 Zig2
Corton Hardcore camping posse 2006!
Jrnbru
Post by Jrnbru »
clymoj wrote:I have a 1500sp with IRS on my very lowered bus and it's great
This is the information I want to hear haha.
Thanks a lot mate. I guess I'll have to try it and see
Joe
