Hi all.
Took the bus out today for the first time since renewing the safari seals.
They needed renewing anyway but I was hoping this would also cure . My whistling noise.
It didn't and, I think the whistling is coming from the offside quarterly.
The quarterlight seals were renewed by the po and they are as new.
Just wondered if anyone had had the same issue.
The whistling begins about 30 mph.
Thanx.
Whistling !!
Re: Whistling !!
I've had this as the rear part of the quarter light glass didn't sit tightly against the seal. I tried to manipulate the seal but it was no good. I've now got a strip of that plastic "U" shaped stuff that holds papers together like this
http://www.viking-direct.co.uk/catalog/ ... GwodOpYIPA
But mine is black so you don't notice it so much against the seal. Pushed on to the glass it now creates the seal much better and I don't get any whistling or if I do I just edge it back against the seal by a mm or so. May be at least worth trying to see if it cures the problem for a little cost and then you can at least know if it is this causing the annoyance and choose your preferred solution.
Re: Whistling !!
Yep my quarter lights whistle, especially the passenger side. I just open it a crack and wear a scarf
What was the Viking direct link?
It didn't go anywhere?
Re: Whistling !!
It works on mine. Just shows the plastic type strip I was talking about.
Re: Whistling !!
Thanx...but link doesn't work for me either. .just takes me to the viking home page?
Sounds worth a try though.
Re: Whistling !!
Mine are terrible. There's a big cap between the seal and the frame where it curves round at the bottom (the most forward part of the frame) and the wind howls through. The seals are clearly too short and have pulled away from the frame. I've got some new ones to try.
Re: Whistling !!
Red Devil wrote:I've had this as the rear part of the quarter light glass didn't sit tightly against the seal. I tried to manipulate the seal but it was no good. I've now got a strip of that plastic "U" shaped stuff that holds papers together like this
Thanks for the tip !
I'm going to try it this year
Jason
he who sins grins
Re: Whistling !!
Nice tipRed Devil wrote:I've had this as the rear part of the quarter light glass didn't sit tightly against the seal. I tried to manipulate the seal but it was no good. I've now got a strip of that plastic "U" shaped stuff that holds papers together like this
I used this http://www.ebay.co.uk/itm/171349305505 as I had some. Works well and you don't notice it
Re: Whistling !!
Pleased it worked. Same principle in that it just needs that little extra to create the seal.
Re: Whistling !!
tried it and works.
thanks guys
thanks guys
