Sump oil temperature sender
StevieJD
Post by StevieJD »
I've got a VDO oil temperature gauge and sump sender fitted to the van. The system has never worked since I bought the van. :cry:
It's eventually got to the top of the 'To Do' list. Last night I checked the + and - to the gauge and they are good. The wire from the gauge to the sender was also checked and it's OK. So it can only be the gauge or the sender.
Has anyone got a sump sender fitted to their engine? I'd like to know the resistance range of the thermistor inside the sender and whether its a positive temperature coefficient - resistance increases as engine oil temperature increases or a negative temperature coefficient - decreases with temperature. I've tried searching the net, but didn't find anything.
If you have one fitted and could measure the resistance when the engine is cold and at normal running temperature, it would be greatly appreciated.
readyboy61
Re: Sump oil temperature sender
Post by readyboy61 »
Is it the type thats fitted in the sumpllate or in the actula engin case? i had one that was in the sump plate and it never moved, howver dropping it into boiling water would get a reading on the gauge. give that a go.
ohms range find the part number on the sender and check there website https://www.vdo-instruments.com/sensors.html
StevieJD
Post by StevieJD »
It's on the sump plate. I found the OEM part number on the JK website and with that, managed to find some info on the VDO website. It's a NTC thermistor so resistance decreases as temperature increases. It should read around 36 ohms at 120 degrees. If anyone has got one on their sump plate and can measure the resistance when the engine is cold, it would be helpful.
kevsplitty
Post by kevsplitty »
I had one on my sump plate,was useless,so got one to go into an adapter on oil pressure switch,works a treat.
Dont walk take the bus!
Rutland Hardcore Posse 07/08/09 Zig2
Corton Hardcore camping posse 2006!
Re: RE: Re: Sump oil temperature sender
kevsplitty wrote:I had one on my sump plate,was useless,so got one to go into an adapter on oil pressure switch,works a treat.
Engine buider advised same location and type.
Works a treat..
redstar5
Post by redstar5 »
I got some adaptors made for the blanking plate to the right rear of the casing. Sender screws into the middle hole. Been running it for a year now and it works well. Never had any luck with the sump ones.
I never put them in the sump, as the cable is too vulnerable plus the sump plate is a service item so better to have the sender somewhere you fit and forget it, like the T3 blanking plate.
StevieJD
Post by StevieJD »
Does anyone sell the adaptors?
Of yours has the blanking plate, just take it off and drill / thread it. If it doesn't have one, you can't use one anyway.
Post by flatbeat »
http://images.thesamba.com/vw/classifie ... 236482.jpg
Joe Bence does them in billet alloy. Get them through TheSamba.
I bought a dump sender for my bug and noticed it pushed against the strainer plate and wouldn't tighten up properly. I called the (well known) place I bought it and their advice was to do it right up so it basically dented/pushed in the strainer plate :eek: Hmm, that'll be pushing it up into the pick up tube - no thanks. I drilled a hole in the strainer for it to fit through but let's face it, that's not ideal. It did work properly. Until I ripped the wire off on a speed hump :lol:
What a waste of time :lol:
On a plus note, the gauge looked cool under the dash :lol:
Post by Who.Me? »
Do you have a particular need to know exactly what the engine temperature is, or do you just want to make sure it's not overheating?
If it's the latter; a Save My Bug dipstick does the job just as well. No need for a dial as it uses the existing oil pressure warning light to tell you when your oil is getting too hot (flashes) or has gone past a maximum temperature (solid light). It's adjustable so you can set the warning temperature and recalibrate it
henk
Post by henk »
I have on my bug also one in the sump and it never worked.
It seems like they don't get a good earth if you put it in the sump.
Henk!!!
redstar5
Post by redstar5 »
I did get a few spare blanking plates cut when I did mine, they are from 5mm stainless with an 8.5mm hole in the middle, I could tap them M10 if required.
PM me if you want one, I'll just need to cover the postage and packing cost
slippy8v
Post by slippy8v »
Can some one put a photo up of the blanking plate in situ with the sender please.
