Jumpy Tacho
Jumpy Tacho
I've installed a Sumex Race Sport tacho in my bus (paid a bit for it rather than a cheap one from ebay).
The tacho needle however jumps all over the place. Sometimes it records about the right revs, sometimes zero, sometimes no where near the right reading.
I have a Lucas coil, Accuspark electronic ignition, new plugs and leads, new dizzy cap and a SVDA dizzy.
I've read that resistance on tachos can be an issue but thought I'd plug into the wisdom of the forum first.
Jonny
OP
Re: Jumpy Tacho
Post by OP »
Have you connected it to a shared earth? If so connect it to it's own earth. I had the same problem with a Mooneyes one years ago and this solved the problem.
Aspro
Re: Jumpy Tacho
Post by Aspro »
You need a diode in line with the coil feed. Cost a few pence from your local electronics store or you can buy them off ebay.
Re: Jumpy Tacho
Thanks chaps - think I'm on a common earth so will get it changed tomorrow and see if that makes a difference.
paul_f
Re: Jumpy Tacho
Post by paul_f »
More likely to need a diode as mentioned by Aspro.
http://thelatebay.com/index.php?threads ... lly.63642/
Re: Jumpy Tacho
Thanks all - 10 diodes ordered for 99p delivered !
Aspro
Re: Jumpy Tacho
Post by Aspro »
Hope it works mate. Let us know
Re: Jumpy Tacho
Post by flatbeat »
JonnyCJ wrote:Thanks all - 10 diodes ordered for 99p delivered !
Which ones did you get......got the same problem.
Re: Jumpy Tacho
Went for the 1N4005
Will report back on how it goes in a week or two. Just dropped the bus off to have some trimming snagging finished off, so will be without it for a few days.
If it works I'll pop the others in the post to you. Can't see me needing any more !
Re: Jumpy Tacho
Post by flatbeat »
Cheers. Fingers crossed it solves the problem :D
OP
Re: Jumpy Tacho
Post by OP »
Fitted numerous tachos and never needed a diode :?
Hongkongphooey
Re: Jumpy Tacho
Post by Hongkongphooey »
Change to its own earth as close as possible to the Tacho. I have an Autometer Tacho was fine on its own earth but I 'Tidied' the wiring up and changed it to a common earth and the needle would twitch as you described, changed back to its own earth and it is fine now...
'60 RHD Devon
Re: Jumpy Tacho
Post by flatbeat »
Hongkongphooey wrote:Change to its own earth as close as possible to the Tacho. I have an Autometer Tacho was fine on its own earth but I 'Tidied' the wiring up and changed it to a common earth and the needle would twitch as you described, changed back to its own earth and it is fine now...
Cool. Mines an Autometer too so I'll check to see if it's got a common earth.....I think it may have...
Re: Jumpy Tacho
Thanks HKP - useful knowledge. Flatbeat- do report back !
Re: Jumpy Tacho
Post by flatbeat »
JonnyCJ wrote:Thanks HKP - useful knowledge. Flatbeat- do report back !
:wink:
