One for the engine experts, popping noise on tickover
Post by 8 8US » Sun Jul 31, 2016 1:40 pm
Can't add the video but a link here to my post on the Facebook page:-
https://www.facebook.com/groups/5540650 ... 116235226/
Any other suggestions?
richandsue
Re: One for the engine experts, popping noise on tickover
Post by richandsue » Sun Jul 31, 2016 6:47 pm
hi Richard have a similar problem with mine. been told it may need re jetting. not done it yet. will be interested to see what other suggestions come up.
Disco Stew
Post by Disco Stew » Tue Aug 09, 2016 2:55 pm
Sounds like an air leak could be the problem. Are the inlet manifolds tightened properly and with good gaskets fitted?
Hongkongphooey
Post by Hongkongphooey » Fri Aug 12, 2016 3:52 pm
Havent seen the video, stupid work PC, but popping on tickover (assuming it is a noise from the exhaust) is normally running lean, if the mixture screw is a little loose they can adjust themselves with engine vibration etc, so maybe worth a little tweak of the adjustment screw?
'60 RHD Devon
