Starter motor issues
Re: Starter motor issues
Post by vwJim » Sat Apr 16, 2016 6:56 pm
If the voltage isn't perfect, or how the gear engages to the flywheel isn't spot on so has to retry but then fails to engage, so then the starter doesn't get the circuit made, so no starting. (which is also why a worn bush has a similar symptom).
dingdong
Post by dingdong » Sat Apr 16, 2016 10:15 pm
I understood the issue is due to heat. Heat causes the magnetism to reduce in the solenoid, so this prevents the solenoid to stop throwing over. This is why it all works if you hot/short wire them straight to the battery. I bet it is only intermittent when it's hot. Let it cool a little and Brumm, away you go. I don't have the hot start relay system and never tested the voltage drop, so perhaps the heat affects that. One or the other for me, but quite rare it happens. Warm day long trip. Wait half hour have a brew and away we go again. Or hot/short wire it.
Post by vwJim » Sun Apr 17, 2016 8:36 am
The emergency wire still uses the solenoid in the same way,
