Starter motor issues
cloudinspector
Post by cloudinspector »
I've been having starter motor problems on and off for a while now. After trying two old ones I've fitted a new Bosch starter but I'm still having issues so I'm wondering if the fault is elsewhere. Basically when the ignition key is turned the lights dim slightly but the starter usually doesn't turn. No click, nothing. However occasionally it decides to turn and start ok.
I've removed the starter and re-fitted, checked the connections are good and cleaned a dodgy earth strap. On first try it turned fine then after that nothing.
Could this be a fault in the ignition barrel? I've thought about shorting out the starter to isolate the ignition switch and see if that works.
Any ideas folks?
1956 PANEL
2009 62' tug style narrowboat (home)
http://www.narrowboatmervyn.blogspot.co.uk
talk is cheap but shouting's free
Samba63
Re: Starter motor issues
Post by Samba63 »
Did you replace the brass bush in the gearbox housing? That's where the end of the spindle of the starter motor engages to complete the circuit to energise the starter motor.
I don't like injustice!
Sjtw
Post by Sjtw »
I would suggest the bush too if you haven't changed it.
That was the source of my trouble.
cloudinspector
To be honest I haven't changed the bush simply because I didn't think it was that critical. Obviously I was mistaken.
1956 PANEL
Robgrav
Post by Robgrav »
Let me know what bush you need. I have a couple brand new kicking about as I seemed to keep ordering the wrong one when I had starter trouble.
MarkFer
Post by MarkFer »
I have exactly this issue - the exact same symptoms.
Went through the usual, low voltage tests etc. Measured voltage at the starter motor with someone turning the key, all good.
Read on here that the starter motor's bush is part of the circuit and if it is worn then that may give the same symptoms. I assume sometimes it touches the motor shaft so the key works, other times it doesn't.
Then I also read a suggestion to run a 2nd cable from the spare terminal on the back of the starter motor through the bulkhead which you can touch onto the battery terminal directly to test. So I did that. So far after a couple of months EVERY time the starter key fails I go to the back, open the hatch, touch the cable onto the battery terminal and it turns over.
I'd love someone to explain.
Mark.
Robgrav
Post by Robgrav »
What starter motor do you have. I ended up running wires, buying new ignition switch, numerous bushes and it turned out to be the starter motor. Months and months I searched and was reluctant to change the starter as it was new on the bus when we bought it. But it was a cheap £70 ish one and complete rubbish. Got a Bosch one now.
MarkFer
Post by MarkFer »
No idea what make mine is, new about 4 years ago but not a Bosch. Still can't understand why mine always works with the direct wire every time the ignition switch doesn't work...
Stevep
Post by Stevep »
Do you have a hot start relay in the starter circuit?
Stevep
Post by Stevep »
Many buses have hot start relays because of distance from ign switch to starter motor!Image
64beetlebaby
Post by 64beetlebaby »
The bell housing bush has nothing to do with completing the starter circuit
it supports the armature ( end bearing ) if it wears the armature runs off center in the motor housing
this can cause the starter to jam in its housing and not engage when the solenoid is asked to operate it has all the symptoms of a bad connection
or low battery voltage
Starter motors can often be bought back to life with new ( bearings ) bushes at both ends polish the commutator and fit a new set of brushes
once the armature is free to rotate and brush contact is good they will work again
a worn support bush will also cause premature wear on the starter engagement dogs and flywheel
cloudinspector
All sorted. New bush fitted and problem solved
1956 PANEL
Sjtw
Post by Sjtw »
:) great stuff. Well done forum!
MarkFer wrote:I have exactly this issue - the exact same symptoms.
Mark.
Jen has one of these emergency wires too, as hers used to do the same.
Hot start relay seems to be the solution on hers, so it's volt drop across the loom.
MarkFer
Post by MarkFer »
Jim - that's what I'd decided on too. I still don't understand why it only sometimes doesn't work though. How do you get a variable voltage drop? Dodgy connection somewhere? The state of the battery charge (not completely flat of course) doesn't seem to effect when it does/does not work.
