Ordering shock absorbers
davebug
Post by davebug » Mon Jan 04, 2016 5:59 pm
Looking at ordering front and back shock absorbers from creative , I have bus set at desired height although not fully built up , suspension is adjustable so after weight added can wind up to same height as is now am I ok to order eye to eye measurements from this or do you have to wait ? Cheers any info great ta
DoubleD
Re: Ordering shock absorbers
Post by DoubleD » Tue Jan 05, 2016 2:01 am
Well, unless there's a burning desire to buy them right now, I would hold off until you are absolutely sure of the finished height. Shocks are very easy to fit after everything else is sorted.
Dave Palmer will help you select the right length when you're ready. I bought Spax adjustable ones from him and they have been excellent.
Hongkongphooey
Post by Hongkongphooey » Tue Jan 05, 2016 4:22 pm
As above, unless you can see it is going to be a delay for when you need them then wait a bit until you have as much as possible pinned down then take your measurements.
'60 RHD Devon
