GEARBOX HELP!!
EL WAPPO
GEARBOX HELP!!
Post by EL WAPPO »
Do any of you kind gents have any infinite wisdom on gearboxes. I have a gearbox that I have been told is a Freeway flyer? It was removed from my van 3 years ago when it ran perfect with my 2110 turbo motor. I have removed the side drain plug to have a nosey inside and nearly fell onto the floor when I noticed the bronze synchro that Is in clear view from the side drain plug has 9 teeth missing. These teeth have not been nicely machined out for a purpose but have been snapped off with force. There were 30 teeth in total but now there are only 21. The pattern is +7 -3 +7 -3 +7 -3. Is it supposed to be like this? Has the synchro ring been modified for some reason or is it ....?
"" YOU CAN'T GET DRUNK ON A WALNUT WHIP"
PEPPE
Re: GEARBOX HELP!!
Post by PEPPE »
cheap repair mode to reuse wornout parts.
tufty65
Re: GEARBOX HELP!!
Post by tufty65 »
Or it's a diy attempt at a pro ring for quicker shifting.
OFF 35
Et 12.64@106.25
http://www.offdrc.co.uk/
