Test running engine outside bus
Haycoxs
Post by Haycoxs »
I'd like to test run my engine before fitting it to the bus as it's been built by me from a Type 4 longblock and I'd like to find any weaknesses/leaks before it goes in.
Has anyone done this and what do I need to do?
Anyone got a test set up (electrics) local to west mids?
Do u need to fit exhaust headers?
Do I need a proper engine stand?
So many questions - any help would be appreciated
Ta
I've always been in the sh*t, it's just the level that changes!
richandsue
Re: Test running engine outside bus
Post by richandsue »
you will need the exhaust fitting as it would not run smoothly enough. be loud as well. only electrics you would need is a 12v to a starter motor on a bell house fitted over flywheel, earth to engine, 12v to coil, small tank of fuel, and then just touch a wire from small terminal on starter to the positive feed, energising the solenoid and it should run. if you have the timing set up ok.
richandsue
ps forgot to mention. as for a stand . have done it before with engine on the floor on a small trolley, does not move much, about the same as if it were in a bus :cheers:
DoubleD
Post by DoubleD »
I have a bell housing you can borrow if you need one.
Haycoxs
Post by Haycoxs »
Thanks DoubleD - I have one but it's catching on the teeth of the flywheel at the mo - need to clearance it a little.
Thanks for the info Rich - was worried it might torque move when started.
What's the best way to wire oil pressure warning light - just a bulb to earth?
richandsue
i believe if you connect a positive to a bulb and then to the pressure switch. the light should come on. then when engine reaches pressure it will go out. not tried this but think thats how it works. :cheers:
211vanman
Post by 211vanman »
Family bucket please !!!
Haycoxs
Post by Haycoxs »
Thanks all - getting there
