Alternator retaining strap Snapped
andy f
Post by andy f »
Out in the bus this evening, got about a mile from home when heard the sound of the cooling fan on tinware. Pulled over check but wasn't expecting to find the Alternator retaining strap had broken.
So the question is , Is it something I have done , can you fit them wrong ?
Andy
scottish splitty
Re: Alternator retaining strap Snapped
Post by scottish splitty »
Don't think you can fit them wrong although it looks as though there has been a bit pressure on the strap were it snapped,probably were alternator sits on the stand.
I snapped two in quick succession recently,turned out to be the fan had elongated the mounting hole and the vibration snapped the straps,
needed a new fan in the end.
The chrome straps are poor quality,might be better with OEM one.
Interesting marking where it has snapped......
In theory.....the strap relies on the force along the strap being spread over the width and length of the strap. .
So if it had been bent at some time that would introduce a possible weak point and stress raiser. .
Looks like corrosion may have contributed and when tightened up causes local high stress at the bent area and corrosion weakens further..
You clamp to stop movement and eventually it gives way. ..
I think...
paulbugman
Post by paulbugman »
is it a repro as looks like one
Interesting that it is black in places and not black in others.
Is this paint and no paint? fretted....or polished away by rubbing?
Maybe it has been loose for a while?
The nut looks to be damaged by tightening...
Sounds like you just need to find another and fit it carefully.!
andy f
Post by andy f »
Well I have ordered 2 replacement ones, One OG from Custom and commercial and then a chaepy one to have just in case it happens again.
So a bit of history on this. about a month ago, we were on our way home after a motorway drive and there was an intermittent noise that on inspection was the fan on the tinware, and yeah the strap had become loose some how. So that would explain some bits I guess.
Hopefully the OEM one will be good and when fitted correctly last a time.
I did get home from work today and make one myself, just like the cheapy ones you get, But I have decided to wait for the OEM one.
Andy
