Problems with aluminum pulley?
Claushema
Post by Claushema »
Thinking about getting a aluminum pulley with etched timing marks but have heard some not great things about aftermarket ones causing damage to the case. Had never heard this before but now that I have I start to worry.
Any thoughts?
Something along these lines:
http://www.machine7.com/product.php?xProd=376&xSec=2294
Thanks,
Dan
Hongkongphooey
Re: Problems with aluminum pulley?
Post by Hongkongphooey »
Have not heard of any damage to cases, have used similar in pretty much all my cars over the years, quality has gone downhill a bit, seen some with the marking slightly off! not great when trying to time a car, I have a Scat one fitted at the moment and it is great, really tight fit but spot on. Try Ritchie Webb here if you are after one as they do all the Scat stuff... http://www.rjvolksperformance.com/
Used them a little while ago for some copper gaskets and the service was spot on :)
'60 RHD Devon
Claushema
Post by Claushema »
Thanks for that. Should I assume that this one is an EMPI?
tufty65
Post by tufty65 »
Some Ali crank pulleys cause oil leaks as they aren't a great fit, why do you want an Ali pulley? I'd keep the stock one of its a stock motor.
OFF 35
Et 12.64@106.25
http://www.offdrc.co.uk/
Claushema
Post by Claushema »
tufty65 wrote:Some Ali crank pulleys cause oil leaks as they aren't a great fit, why do you want an Ali pulley? I'd keep the stock one of its a stock motor.
Good question. I had the idea that finding the 28-32 mark would be easier but then again marking it with a protractor seems easy as well. Never mind.
