Front bumper gap?
oilyragg
Front bumper gap?
Post by oilyragg »
Fitted the lower front panel and the nose today :cheers: and tried on the front bumper which fitted fine in the chassis holes but there is about a 40mm gap between the front panel and the bumper and almost touching at the sides, is this right or should it be tighter to the front?
Archie3781
Re: Front bumper gap?
Post by Archie3781 »
That does look a bit proud, but not by much at all, it's mostly how you want it, if your all the way in on your slots, and don't like it, you've got some work, not much though, also, should be snug to tides, mines pretty close too.
oilyragg
Post by oilyragg »
Ok thanks Archie.
