electronic ignition.
suzanne63split
Post by suzanne63split »
im in the market for an electronic ignition set up for my 1641 tp engine. ive read a bit but still no idea which is best and value for money. has anyone used the acuspark system they seem to have a good right up and good value for money.
modifiedbrian
Re: electronic ignition.
Post by modifiedbrian »
Got one on my spare engine.
Think its great for the money.
2276cc fuel injected turbo 1967 SO42
Best ET 14.66
YOUR ONLY SUPPOSE TO BLOW THE BLOODY DOORS OFF !!!!
Post by ted698 »
I use the powerspark one, from simonbbc (google it, or look on ebay), its been on my van for over a year, and its way, way cheaper than pertronix etc, think it was about £28 when I bought mine, its been faultless,and fitted in minutes.
Set of points and a condenser on mine. Been on there in various guises since 1964 and never had any problems. Cost 7 quid per set and can be changed and adjusted at the side of the road with a screwdriver in a couple of minutes if they go wrong (which they never have).
Out of interest, why do you think you need electronic ignition on a 1641? It's just more electric stuff to go wrong and leave you stranded in my opinion.
Cheers, Lee.
Claushema
Post by Claushema »
e m p i wrote:Set of points and a condenser on mine. Been on there in various guises since 1964 and never had any problems. Cost 7 quid per set and can be changed and adjusted at the side of the road with a screwdriver in a couple of minutes if they go wrong (which they never have).
Cheers, Lee.
I've got points on all 3 of mine and never once had a problem. As far as I know neither did my mom back in 54' with her bug. Don't really see why I should change something that works fine.
ziggy
Post by ziggy »
I've gone through 2 pertronix, both failed for different reasons, I have also tried a powerspark unit but it was very lumpy at low rpm, having said that it was in one of my spare Chinese dizzy's. I'm afraid it points for me, easy to get hold of, cheap and can be replaced/adjusted on the roadside. However I'm a big believer of only using vw or bosh points and setting them up with a dwell meter, Experence has shown the cheap chinesse points don't give the correct dwell when set using feeler guages, don't line up correctly, need constant adjusting and dont last 5 minutes. Personally I think it's these cheap parts which has given the impression point are crap and pushed people towards the dark side, don't get me wrong I'm sometimes tempted, just for the sake of it, but you have to resist the pull of the dark side. Oh I'm running a 1776 :wink:
OP
Post by OP »
I ran an Accuspark cheapo dissy on my bus for a year then it started to over advance and was playing up big time. Luckly I noticed when I checked it all over before EBI last year or it would have cooked the engine!! The poor chinese casting should have stopped me using it really.
Back on an original Bosch dissy with points and condensor on a twin Weber'd 1641 and nooooooo problems again.
henk
Post by henk »
I always wanted a electronic ignition on my beetle as well.
I bought a complete MSD systeme,worked great when new but a year later the problemes start.
Went back to a bosh 010 with points and now i get everywhere again.
Henk!!!
Kranjam
Post by Kranjam »
I am in the points camp too.
Had a starting problem and didn't want to believe the electronic ignition was the problem but it was.
Andy
suzanne63split
thanks for all your replies. i think i will stick with the points then.
