Nose Cone / Gearshift seal
chessfoss
Post by chessfoss »
Apologies if I'm using the wrong section. I have a 1964 splitty and its leaking oil from the nose cone at the gear selector shaft. It has reduction boxes ( hoping this helps to identify the gearbox) .
I was wondering if there is a source of repair seals / kits? or if a new nose cone is easier / better as I read it was difficult o get the seals.
Thanks for any help!
Re: Nose Cone / Gearshift seal
Try custom & commercial - pretty easy to navigate to the correct section ! Replacement bushes are available.
Jonny
chessfoss
Post by chessfoss »
Thanks Jonny,
They appear to have them for bay windows but they're not sure 131301225A if this will work on a splitscreen. They have a bushing for the splitscreen 111301207 but not the seal kit???
jayvanman
Post by jayvanman »
Here you go, this should help.
Learn from my mistakes, better than learning from your own ;-)
viewtopic.php?f=8&t=70593&hilit=benidict&start=45
Jason
he who sins grins
