Creative rear shock mounts
Slippers
Post by Slippers » Wed Jul 30, 2014 7:37 pm
I am trying to fit a Creative IRS kit to the rear of my bus but am a little concerned about where the rear shock mounts fit. If I were to fit as per the instructions then I would be cutting through the joint where two panels meet and and would take away the strength in the joint.
To be honest I wish I never started it but I have already removed the original frame horns so I can't really go back now. Does anyone have any advice on how I should do this?
split999
Re: Creative rear shock mounts
Post by split999 » Thu Jul 31, 2014 3:44 pm
Get under your van and ring Dave at Creative. That's what I did and was then mystified as to why I couldn't work it out for myself!
Very easy when he talks you through it, and don't give up!
:wink:
66 UK RHD 11
70 911 Coupé
59 NSU Prima III KL
Slippers
Post by Slippers » Thu Jul 31, 2014 4:08 pm
Been trying to ring Dave all day but no reply. Even thinking now about throwing the mounts and making my own.
mjknight71
Post by mjknight71 » Thu Jul 31, 2014 6:13 pm
would a pic help :? ....if i remember i will take a picture of mine over the weekend :roll:
Slippers
Post by Slippers » Thu Jul 31, 2014 6:20 pm
Yes a pic would help, Markp has said he will send some as well. :)
split999
Post by split999 » Thu Jul 31, 2014 6:30 pm
Here. Quick google
viewtopic.php?f=6&t=39610&start=0
Scroll down the page a bit
:wink:
66 UK RHD 11
70 911 Coupé
59 NSU Prima III KL
DoubleD
Post by DoubleD » Thu Jul 31, 2014 7:24 pm
I decided that I didn't want to cut away any metal, so I shortened the mount, re-drilled it, ground the back flat and fitted it as shown with a reinforcing plate behind, inside the chassis channel. I discussed it with Dave Palmer and he thought it would be fine - and it is. The top bolt goes right through, ie. two bolts through the chassis.
Slippers
Post by Slippers » Thu Jul 31, 2014 7:33 pm
What a brilliant idea, saves me cutting. Thanks for that.
markp
Post by markp » Thu Jul 31, 2014 9:04 pm
Few pics of mine fitted
I've covered over 4k .... And no problems with it at all
But if you can design a way of not cutting off the lip then its nicer for ya bus I guess :cheers:
tufty65
Post by tufty65 » Fri Aug 01, 2014 10:34 am
you could turn the mount horizontally to follow the line of the chassis arm, that's what I did with mine as it saves cutting out the inner panel work.
OFF 35
Et 12.64@106.25
http://www.offdrc.co.uk/
DoubleD
Post by DoubleD » Fri Aug 01, 2014 11:21 am
Whichever way you do it, you'll need to size your shock length accordingly. Creative show a table on their website to assist with this. If you get it wrong, you can damage the shock absorber and waste a lot of money. Dave Palmer was very helpful over choosing the right length - it all depends on the ride height with a normal load on board. My advice would be don't buy the shock absorbers until the suspension has settled down and the height is finalised.
henk
Post by henk » Tue Jun 06, 2017 8:30 am
I have bought the CE universale shock mouts for my bus with beetle IRS.
But i can't get shock in to a straight position with these.
The shocks are pointing way to much to the outside.
I can make the mounts smaller so that the shocks come closser to the chassis and stand more straight then.
Anybody else who has used these mounts,or see another probleme.
Henk!!!
rustysplit
Post by rustysplit » Tue Jun 06, 2017 9:27 am
Just started my IRS conversion.
Creative sell two sorts of shock mount. The one I think you are trying to fit and a "self locating" one which just slides into position against the corner of the fuel tank floor. Looks OK regarding my test fitment but I have not yet bolted it up or tried position relative to shocks.
Hope that helps. PS "self locating" is about £5 more expensive.
DoubleD
Post by DoubleD » Tue Jun 06, 2017 10:51 am
As far as I am aware, the CE shock mounts are normally used with the early bay type of rear hub carriers. Yours look like the Beetle or Porsche variety, in which case the chassis shock mount and the hub carrier shock mounting point may not line up correctly. I may be completely wrong, but all I can say is that mine lined up properly using the early bay hub carriers.
A call to Dave Palmer at CE would confirm this one way or the other.
susta
Post by susta » Tue Jun 06, 2017 4:16 pm
The latest version is the one to use, no cutting and only one location
