Chassis number
Taffy
Chassis number
Post by Taffy »
I'm looking at van with a view to a purchase. I'm told it is a 62 and imported from Indonesia but can't find the Vin plate. There's a number stamped into the chassis next to the engine - 5090651 - does this make any sense to anyone ? It also has non standard rear lights which are not flat but stick out - any thoughts?
Rob b
Re: Chassis number
Post by Rob b »
Here's a good site to help you with chassis numbers http://www.thesamba.com/vw/archives/inf ... dating.php
An looking at the numbers you put on your post I'm
Not sure what they are. There should be a plate in the engine bay an one around the seat bulkhead area
Hope that's helps
Rob
Marvelwear
Re: Chassis number
Post by Marvelwear »
62 will be stamped either side under the tank facing out. Some that were made were ckd and may never have had plates or had panels replaced.
