BANDED STEEL WHEELS
BANDED STEEL WHEELS
Post by 24879845 »
Guys,
I was thinking of have a set of standard 14" steels wheels banded..
Making the rears wider and the fronts narrower? Any recommendations for width for front and rear?
Kind Regards
Jamie
Re: BANDED STEEL WHEELS
Post by ted698 »
I thought banded wheels were illegal, but seems It may be all myth and legend.... see this...
http://ssvc.org.uk/phpbb/viewtopic.php?f=2&t=48828
readyboy61
Post by readyboy61 »
Steel banded wheels a UK company and has done many a vw, I'd go for 6inch total on the rear
Fixing VWs in my sleep, im not the only one right?
GW BUS
Post by GW BUS »
I'm running banded steels on my bus and I think they look great with the different depth of rim showing on the front and back wheels.
Post by 24879845 »
So 6" rear any suggestion on the front?
Kind Regards
Jamie
GW BUS
Post by GW BUS »
I've got banded on the back and stock rims on the front, because the back are banded it gives the wheels a different dish making them look different sizes.
thesickness
Post by thesickness »
Just bumping this thread as i'm looking to band 14 inch steels on the rear as well. I have earlybay irs setup on rear so I have plenty of room to widen the track a bit and bring the wheel 'out' towards the wheel arch. Only thing getting me worried is getting the wheel on or off. I'm not stupidly low and tried it with a 195 70 14 on a standard rim and it just squeezed under the arch.
Dc67
Post by Dc67 »
I banded my rear 15inch wheels by adding 50mm to the outside on an IRS set up and they just fit under the rear arch and then banded the front by adding 30mm to the inside this allowing maximum clearance of the wheel arch and actually looks more like I'm running a narrowed beam
Hope this helps
thesickness
Dc67 wrote:I banded my rear 15inch wheels by adding 50mm to the outside on an IRS set up and they just fit under the rear arch and then banded the front by adding 30mm to the inside this allowing maximum clearance of the wheel arch and actually looks more like I'm running a narrowed beam
Hope this helps
Thanks for that, can I ask what size tyres you're running so I can put the figures in a tyre size calculator and end up with a similar size diameter with my 14 inch wheels.
Dc67
Post by Dc67 »
Hi sorry for poor response
I'm running on the back 185/65/15
Front 165/50/15 Bridgestone protenzas
Hope that helps
thesickness
Well the wheels have arrived and I'm now concerned about tyre choice on rear. They are 7inch and from looking on tyre sites it seems that the widest available in 14 inch are 195 65 or 195 70.... Diameter is fine but wanted a bit wider, like a 205... Any ideas?
maddison
Post by maddison »
if you just want the rears to have more dish….but still wanna be able to get them on and off
have you considered type 3 14" wide 5 steels…look like bus wheels but have a more dished offset
I have a set on the rear of my bus
(I use them because they sit further out they clear my adjustable spring plate adjuster better ;-)
basically, they look like banded bus wheels, but you have the added bonus of them not rubbing on the inside and185/14 tyre fits perfecto
oh…and they haven't been cut and shut ;-)
thesickness
Just want a wider wheel on the back to fill the arches...They been done at bandedwheelsessex and look amazing in finish and quality of workmanship...they've been banded outwards so as not to foul the adjuster...
Aspro
Post by Aspro »
maddison wrote:if you just want the rears to have more dish….but still wanna be able to get them on and off
Are you sure the type 3 steels aren't 15's too?
maddison
Post by maddison »
pretty positive, have a pair on the arse of my bus, wearing 185/14 tyres
